Dual point distributor issues.
#2700163
09/23/19 03:18 PM
09/23/19 03:18 PM
Posts: 4,179 California
mickm
California
Put a dual point in the car that I rebuilt a while ago. Needed a new bushing, shaft was loose. Don't remember what else I did, but it's in good shape.
Put a new set of Blue Streak points in, and a condenser, not sure of manufacturer, and installed it in the car.
It starts and runs, idles, fine, but when I took it out to test drive it immediately was falling all over itself, stumbling and didn't really seem to want to rev. I didn't push it at all, I'm sure this is around 2000-2200 rpm, not much more, no tach at the moment.
I disconnected the vacuum advance, as well as put a brand new Blue Streak condenser in, no change.
I had used a formula I got off the board here to limit my advance, and welded the slots to get me about 12-14 degrees. With my initial at 20 though, when I bring the rpms up, I'm in the 42-44 range. I don't know how it can possibly be that much, even if I used the wrong value to calculate how much to weld up, I still eliminated a fair amount of travel in that slot.
The other thing I saw was that at idle, the timing light was fine, firing every revolution. Once up in the RPM, it appeared erratic, somewhat in line with the engine sounding like it was missing.
Any thoughts? I doubt two new condensers are bad, but could be. I'm going to try a different rotor, isolating each set of points, but not sure where to go beyond that.
Re: Dual point distributor issues.
[Re: mickm]
#2700196
09/23/19 05:36 PM
09/23/19 05:36 PM
RapidRobert
Just thinking out loud. shaft (bushings) tight & axial end play OK? adv plate pivot tight? points gapped correct? It ran OK with the prior dist in there?
[Re: RapidRobert]
#2700225
09/23/19 07:16 PM
09/23/19 07:16 PM
mickm
California
Just thinking out loud. shaft (bushings) tight & axial end play OK? adv plate pivot tight? points gapped correct? It ran OK with the prior dist in there? Yes to all of these.
[Re: Cudajon]
#2700226
09/23/19 07:18 PM
09/23/19 07:18 PM
mickm
California
Need to get a hold of a dwell meter, better yet find someone with a good old fashioned sun distributor machine and set that up correctly. I've seen brand new distributors loose their mind at 1k and above. Also a machime will let you fine tune the vacuum and centrifugal advance. I used to teach auto shop and i would let guys come in and use mine so check there. Forgot to put this in my initial post. Dwell seemed to bounce around just a bit, but when the RPM was up a little, it was a solid 32. That probably is the way to go, especially since I'm having issues. I'm wondering if it is something mechanical, as it doesn't make sense that I should have that much advance, considering I welded up that slot. The issue is finding someone with a machine...
[Re: dragon slayer]
#2700229
09/23/19 07:21 PM
09/23/19 07:21 PM
mickm
California
How small is that slot. Your basically saying you have a cam plate with 6deg. X2 to give you 12 at rpm, on top of your 20. If you did the slot like a normal 12deg, that is actually 24deg at rpm and may be why your in the 42 to 44 range. Not sure I follow. The slot is what allows the advance, as the RPM overcomes the spring pressure. Once the pin is at the end of that slot, advance stops. I think the stock advance is in the 20+ degree range. The chart I found on here listed the length of that slot for the amount of advance you want, so I welded the slots and then filed them to get the exact slot length. Are we talking the same thing here?
[Re: mickm]
#2700246
09/23/19 07:52 PM
09/23/19 07:52 PM
RapidRobert
He means is the 12 deg, dist degrees (which would show 24 on the dampener) or is the "12" actually crank (dampener) degrees EDIT .340" length on the slots would give you 12 on the crank & .435" would give you 24 on the crank
[Re: RapidRobert]
#2700266
09/23/19 08:43 PM
09/23/19 08:43 PM
mickm
California
He means is the 12 deg, dist degrees (which would show 24 on the dampener) or is the "12" actually crank (dampener) degrees EDIT .340" length on the slots would give you 12 on the crank & .435" would give you 24 on the crank Got it. I don't remember, but I'm guessing from what I'm seeing that I did 12 at the distributor.
[Re: mickm]
#2700278
09/23/19 09:25 PM
09/23/19 09:25 PM
Posts: 1,328 VA
dragon slayer
VA
He means is the 12 deg, dist degrees (which would show 24 on the dampener) or is the "12" actually crank (dampener) degrees EDIT .340" length on the slots would give you 12 on the crank & .435" would give you 24 on the crank Got it. I don't remember, but I'm guessing from what I'm seeing that I did 12 at the distributor. That would be your issue then. Put initial at 10deg and see how it runs. The marking stamped on the distributor cam stop is normally distributor advance for Prestolite and Mopar. So if it is 8 or 12 it gives 16 or 24 at the crankshaft. You double it. The CAP (Mopar emission) distributors starting in 1968 had about 15deg cam stops for 30 advance. That is why initial was a 0 to 2 Deg BTDC. Is there a reason you think you need 20 deg initial timing?
[Re: dragon slayer]
#2700283
09/23/19 10:01 PM
09/23/19 10:01 PM
mickm
California
He means is the 12 deg, dist degrees (which would show 24 on the dampener) or is the "12" actually crank (dampener) degrees EDIT .340" length on the slots would give you 12 on the crank & .435" would give you 24 on the crank Got it. I don't remember, but I'm guessing from what I'm seeing that I did 12 at the distributor. That would be your issue then. Put initial at 10deg and see how it runs. The marking stamped on the distributor cam stop is normally distributor advance for Prestolite and Mopar. So if it is 8 or 12 it gives 16 or 24 at the crankshaft. You double it. The CAP (Mopar emission) distributors starting in 1968 had about 15deg cam stops for 30 advance. That is why initial was a 0 to 2 Deg BTDC. Is there a reason you think you need 20 deg initial timing? That is the reason I have so much advance, but I don't think this is the cause of it running so badly. After all, with vacuum advance, the engine could easily be at 44 degrees or more and 2200 rpm moving down the road. I will move it back to 10 and see if that makes a difference. It's a Hemi. They like a lot of initial.
[Re: mickm]
#2700334
09/24/19 06:50 AM
09/24/19 06:50 AM
Posts: 3,916 usa
lewtot184
usa
Need to get a hold of a dwell meter, better yet find someone with a good old fashioned sun distributor machine and set that up correctly. I've seen brand new distributors loose their mind at 1k and above. Also a machime will let you fine tune the vacuum and centrifugal advance. I used to teach auto shop and i would let guys come in and use mine so check there. Forgot to put this in my initial post. Dwell seemed to bounce around just a bit, but when the RPM was up a little, it was a solid 32. That probably is the way to go, especially since I'm having issues. I'm wondering if it is something mechanical, as it doesn't make sense that I should have that much advance, considering I welded up that slot. The issue is finding someone with a machine... dwell should be between 37 and 42 degrees; overlapping points. 42-44 degrees total is way too much.
[Re: TJP]
#2700584
09/24/19 08:24 PM
09/24/19 08:24 PM
mickm
California
dwell should be between 37 and 42 degrees Ok, I must have been in the wrong section in the FSM, I saw 28-32. It's been many years since I have messed with points! But, if I isolate EITHER set of points, it runs great. Bring the other set in, and all the issues. So is a total dwell of 32 enough to cause this issue? doesn't seem like it to me...
[Re: mickm]
#2700588
09/24/19 08:33 PM
09/24/19 08:33 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
dwell should be between 37 and 42 degrees Ok, I must have been in the wrong section in the FSM, I saw 28-32. It's been many years since I have messed with points! But, if I isolate EITHER set of points, it runs great. Bring the other set in, and all the issues. So is a total dwell of 32 enough to cause this issue? doesn't seem like it to me... I would reset both sets. I had a old Accel dual point and as soon as the rubbing block wore the points would stay closed to long and the car ran poorly. On a lot of performance dual points the point sets have a lot of spring tension so the blocks wear. Make sure you are using lobe lube. If it were me I would set them with a feeler gauge and recheck the timing.
