Re: 1951 Plymouth Cambridge
[Re: Sniper]
#2941127
07/08/21 10:26 AM
07/08/21 10:26 AM
Posts: 6,238 nowhere
Sniper
nowhere
So I pull the bearing from the cap to look for sizing and date codes. You know I do have 13 letters in my last name. What the heck is a brass shim doing under the insert?
[Re: NITROUSN]
#2941307
07/08/21 06:09 PM
07/08/21 06:09 PM
Sniper
nowhere
That was a typical way of taking up the slack. Old FSM's as I recalled even told you how to do it.
. Thanks, my FSM is a consolidated reprint that doesn't really address that. I have been looking for a real 1951 Plymouth FSM to no avail. I do have a Motors Manual that covers that era though. Gotta finish the tear down and start mic'ing things out. That will tell the tale.
[Re: DynoDave]
#2942387
07/12/21 05:15 PM
07/12/21 05:15 PM
Sniper
nowhere
Looks very clean in there. Except for the piston skirt pieces of course... Yes sir, till I found the skirt pieces I was thinking I might be able to get away with a cleanup and not a rebuild. Still need to mic the bores and such to determine the future direction.
[Re: Sniper]
#2945977
07/22/21 10:48 AM
07/22/21 10:48 AM
Posts: 1,821 South Bend
John Brown
South Bend
I no longer have any stuck valves and they go up and down as designed. So, next time you have a stuck valve to deal with maybe this will help.
Thanks for that reminder. I know that brake fluid 'creeps', but had forgotten. I have a carb with a stuck shaft. Gonna try the b fluid trick.
[Re: DynoDave]
#2967175
09/24/21 11:25 PM
09/24/21 11:25 PM
Sniper
nowhere
Brake fluid for stuck valves. I've not heard that one before. Glad it worked. Interesting that you bring this back up. I rolled the engine over to day for the first time since I did the brake fluid trick. 2 months of sitting and the valves still do not stick, I'm going to say this trick works.
[Re: Sniper]
#2970243
10/04/21 09:32 AM
10/04/21 09:32 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Got some time in on the Cambridge today.
Putting disc brakes on the front. Well, some days you avoid the snowball, other days the snowball runs you over.
Going to have to take the uprights steering kniuckle to the machine shop to get new kingpins fitted up. Tie rod ends need replaced, steering box needs adjusting and if I am reading the date code correct I probably have the original hydraulic shocks.
Front shocks are damned expensive if you want stock hydraulic types. Pass. Did a bit of measuring adn found an alternate, 60-62 C10 front shocks will fit and work. Not to mention you can get good, gas charged ones for a reasonable rice. All will be very nice upgrades.
