Re: my rear axel got bent from welding
[Re: Mr500_wedge]
#269592
03/28/09 02:56 PM
03/28/09 02:56 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I would cut the ends off and weld them back with a narrowing jig.
[Re: John_Kunkel]
#269593
03/28/09 03:13 PM
03/28/09 03:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'd cut it otherwise that tire will have a toe in or out issue (cant see which way is front) just cut it most of the way through and tap it straight then reweld it SLOWLY with time to cool
[Re: MR_P_BODY]
#269596
03/28/09 04:00 PM
03/28/09 04:00 PM
Posts: 981 Way North Illinois
JandJ_Racing
Way North Illinois
I ran a bar through it end to end and also removed the spool and put the caps around the bar. Keeps everything straight. Not sure how to do that on an eight and three quarter (mine was a Dana)
[Re: JandJ_Racing]
#269598
03/28/09 04:34 PM
03/28/09 04:34 PM
That is the problem with 8-3/4 rear ends..The housing is weak...I bent mine so much the car sat 1-1/2" lower on the right side....Go to a dana.
[Re: slantzilla]
#269601
03/28/09 05:23 PM
03/28/09 05:23 PM
MR_P_BODY
It's suprising how "bent" most 8-3/4 housing are from the factory.
You think 8-3/4" housings are bad, you should check out the 8.8 housings in Mustangs.
WOW, I must be really good... I've never had a problem welding/shortening the 8 3/4s
[Re: MR_P_BODY]
#269603
03/28/09 05:55 PM
03/28/09 05:55 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
It's not a problem but just causes the ends to be offset from the housing which doesn't look correct but is correct. btw the bend/offset becomes much less as the housing become more narrow which is probably what you are dealing with. Take a look at a c-body, truck or van housing with a narrowing bar installed a you will see that the center of the bar is probably somewhere near 1/8" offset from the center of the housing end. But cut that same housing for a tubbed car and the offset would be much less, possibly close to perfect. It's also interesting to see the difference in the housing from one side to the other. One end might be perfectly centered while the other end is nowhere close. Good old quality control..or lack of. Oh well, it worked.
[Re: DoctorDiff]
#269604
03/28/09 05:57 PM
03/28/09 05:57 PM
Quicktree
I straighten most housings, regardless of brand, before I weld them together. I like to see the housing end centered on the tube.
Installing a through-bar or axles does nothing to control warpage while installing a back brace.
I know you are right, but I would rather have them in vs nothing. and welding them in 1" spots is the way I have done it a few times. are they perfectly straight ? probably not but it works well enough on a low HP bracket car.
[Re: 446acuda]
#269605
03/28/09 06:04 PM
03/28/09 06:04 PM
dartman366
Mt. Vernon, Ohio
I alway's cut the end's off then do all my welding and brackets, then the last thing you do is weld the end's back on with a jig to get the wheel bearing bores in alignment with the bearing's in the carrier,,,your bearing's and seal's will thank you.
[Re: dartman366]
#269606
03/28/09 06:11 PM
03/28/09 06:11 PM
MR_P_BODY
Thats the way I do it, the bearing ends are always last going on.... by rights that tube could be all over the place as long as the ends are square to the carrier bearings and I like the tire square to the car
