LA 360/727 into '94 Dakota...
#2694343
09/04/19 01:16 PM
09/04/19 01:16 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Found a nice little truck with a bad 3.9 for cheap. Just happen to have a low mileage '77 360/727 combo on hand. Any mounts available for this swap? IIRC, LA engines won't accept Magnum mounts and most folks are swapping Magnums into older vehicles, not vice-versa. Just spitballin' here... Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: LA 360/727 into '94 Dakota...
[Re: I_bleed_MOPAR]
#2694377
09/04/19 02:25 PM
09/04/19 02:25 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
[Re: I_bleed_MOPAR]
#2694407
09/04/19 04:14 PM
09/04/19 04:14 PM
Posts: 129 SE Indiana
kowalski440
SE Indiana
Schumacher HAD what you need.They WERE Pricey, though (maybe why they were discontinued!).
Last edited by kowalski440; 09/05/19 07:45 AM. Reason: Reflecting next poster's reply to my original wording.
[Re: kowalski440]
#2694482
09/04/19 08:50 PM
09/04/19 08:50 PM
I_bleed_MOPAR
Buford, GA
Afraid of that but just looked and says discontinued. Tim
[Re: kenworth_goose]
#2694592
09/05/19 07:50 AM
09/05/19 07:50 AM
kowalski440
SE Indiana
Great tips! I need to file this info away... I've done the swap a few times. I use truck brackets and mounts and fab a box on each side of the frame and I always move the engine and trans. back to the firewall. They actually handle much better when you move the engine back. If I remember right it's 2 1/2 inches back. I use 3/16 plate to make the boxes for the mounts. I put slots in them just like the trucks. It;s a very easy job if you can weld.
#2694668
09/05/19 11:50 AM
09/05/19 11:50 AM
I_bleed_MOPAR
Buford, GA
I've done the swap a few times. I use truck brackets and mounts and fab a box on each side of the frame and I always move the engine and trans. back to the firewall. They actually handle much better when you move the engine back. If I remember right it's 2 1/2 inches back. I use 3/16 plate to make the boxes for the mounts. I put slots in them just like the trucks. It;s a very easy job if you can weld. Now, that's what I was looking for. Thanks, k w g. Tim
[Re: I_bleed_MOPAR]
#2694823
09/05/19 11:07 PM
09/05/19 11:07 PM
Posts: 2,046 ky.
kenworth_goose
ky.
I've done the swap a few times. I use truck brackets and mounts and fab a box on each side of the frame and I always move the engine and trans. back to the firewall. They actually handle much better when you move the engine back. If I remember right it's 2 1/2 inches back. I use 3/16 plate to make the boxes for the mounts. I put slots in them just like the trucks. It;s a very easy job if you can weld. Now, that's what I was looking for. Thanks, k w g. Tim You are welcome!
