Master cylinder question #269162
03/28/09 07:00 AM
03/28/09 07:00 AM
east coast
Otherlane Offline OP
east coast
I have asked before but i cant find the post,whats a good master cylinder for a 4 wheel disc brake car? I was thinking about buying the one from member rick ehrenburg he has new mopar master cylinder for $73 shipped.i just dont know which one to get,like the bore size etc etc? Or can i use my stock manual master cylinder? also do i need a proportioning valve? If anyone give me infor can you give me a part number on a master cylinder i should get? im running wilwood brakes i dont think they would make a difference
Re: Master cylinder question [Re: Otherlane] #269163
03/28/09 07:10 AM
03/28/09 07:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you see Quicktree's post on masters, lots of info.
The master you are looking at is a 1.125 bore. With
4 wheel disc you are most likely going to need the big
bore but that is dependent on the piston sizes in the
calipers and pedal ratio.... if you go to a large bore
and it isnt needed you will have a pedal that doesnt
move much and would be rock hard
Re: Master cylinder question [Re: MR_P_BODY] #269164
03/28/09 07:33 AM
03/28/09 07:33 AM
east coast
east coast
Thanks P-body and I will look for quicktree post
Re: Master cylinder question [Re: MR_P_BODY] #269165
03/28/09 11:06 AM
03/28/09 11:06 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Hmmm, so what would it mean if I have 4 wheel disc and the first push is soft and down quite a bit but the 2nd push is much harder It does not feel right but now sure how to fix it, smaller bore?
Re: Master cylinder question [Re: max_maniac] #269166
03/28/09 11:12 AM
03/28/09 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like you still have air in the lines...
are you using braided line all the way? If so,
thats part of it
Re: Master cylinder question [Re: MR_P_BODY] #269167
03/28/09 12:10 PM
03/28/09 12:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats part of it
that or he has aerospac
