Dana parts on the scale
#2690795
08/23/19 10:37 PM
08/23/19 10:37 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Had a few parts on the scale to compare between spool and power lock
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Dana parts on the scale
[Re: b1dartsport]
#2690941
08/24/19 02:56 PM
08/24/19 02:56 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
Weighed a Dana 60 Eaton Trutrac Diff last week and it was 42 lbs. Those things are PIGS!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: MadMopars]
#2690975
08/24/19 04:50 PM
08/24/19 04:50 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
The only bad thing on using spools on the street is making tight turns like parking or backing into a small space to park. Some street people will look at you funny when your making those type tight turns when the car and tires are making more noise than usual
