In distress... help? #2690082
08/21/19 05:22 PM
08/21/19 05:22 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Does anyone have a listing of engine bearings by bore size? I have an early Hemi (331) that Ive done a lot of work to, only to now find that the main bearing bores were made oversized at some point before me getting it. I built main caps for it. Made the bores of them undersized for fitment. I was just at the machine shop and they wanted to know what finished bore size I wanted... because the block had already been line bored over standard size.
The bore spec is supposed to be 2.6565”- 2.657”
The bore is now approximately 2.688” (best i could measure without the actual original caps)
All bearing bores look good and measure about the same, they are just incorrect for this block.
I assume the block was damaged at some point and someone adapted some other bearing into this block.
Crank journal is at -.010 (2.500 journal)
Any ideas/ solutions???
Re: In distress... help? [Re: TRENDZ] #2690084
08/21/19 05:30 PM
08/21/19 05:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With a 2.500 bore I wouldnt think thats too hard to find.. just guessing
wave
Re: In distress... help? [Re: MR_P_BODY] #2690121
08/21/19 08:09 PM
08/21/19 08:09 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
I just checked my A8 sprint car block. Looks like someone may have just made the hemi block accept 340 main bearings. Actually happy now instead of worrying.
Re: In distress... help? [Re: TRENDZ] #2690172
08/21/19 10:26 PM
08/21/19 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad to see that your happier now,, I forgot that I had just checked my 340 block for bearings
wave
Re: In distress... help? [Re: TRENDZ] #2690267
08/22/19 09:39 AM
08/22/19 09:39 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
long time ago I did a 354 hemi, and I forgot his name but a guy had all kinds of LA engine parts that would fit the Hemi. I think I used a LA oil pump with an adapter, 340 six pack flywheel, I think the timing chain interchanged as well. So that modification may have been done as well, on your bearings.
Re: In distress... help? [Re: jwb123] #2690353
08/22/19 01:44 PM
08/22/19 01:44 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
There are a lot of 331-354s running around with 340 mains and pontiac rod bearings. Think the mains was just a rebore, rods had to be bored .005 or so, and have the tang slots moved. Been 30 years since I did one, bearings were hard to find then.
Re: In distress... help? [Re: 4406bbl] #2690376
08/22/19 03:07 PM
08/22/19 03:07 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Good to know. Unfortunately, I was able to find bearings for a stock bore, 010 under crank for a 331. Fairly spendy$$$.
Now I have to seek out a set of 340 bearings, which I would imagine are easier to find, cheaper, and have a wider selection of options.
All around though, Im glad it is what it is.
Re: In distress... help? [Re: TRENDZ] #2690381
08/22/19 03:52 PM
08/22/19 03:52 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Call Ron Farley racing engines. 716-799-5588.
He specializes in early Hemis
We use many of them as counter weights around the shop.
