Hemi Block Serial Numbers #268629
03/27/09 07:29 PM
03/27/09 07:29 PM
Ohio
RestoreCuda Offline OP
Ohio
I recently looked at a Hemi Blk dated 6/8/69 with no numbers or symbols on the distributor pad. The VIN pad is 0G followed by the sequence #. Is this a warranty blk with the VIN restamped? Sorry if this has already been covered.
Re: Hemi Block Serial Numbers [Re: RestoreCuda] #268630
03/27/09 07:59 PM
03/27/09 07:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No such thing as a "Serial" number on a Hemi. Post clear pics of your discoveries and we can give you more feedback. Also look on the oil pan rail extension (rear on bottom) for other stampings.
Re: Hemi Block Serial Numbers [Re: ScottSmith_Harms] #268631
03/27/09 08:11 PM
03/27/09 08:11 PM
Ohio
Ohio
Thanks I understand. Sorry I don't have pics yet. I guess what I really wondered is are there unmolested Hemi blks with blank distributor pads?
Re: Hemi Block Serial Numbers [Re: RestoreCuda] #268632
03/27/09 08:17 PM
03/27/09 08:17 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
More likely, the block has been decked.
0G would indicate that it was from a B-Body.
Re: Hemi Block Serial Numbers [Re: Snoopy] #268633
03/27/09 08:21 PM
03/27/09 08:21 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
In 1970 most of the info was not on the upper pad, it was on the other areas I described. Or as Snoop said, it's been decked.
Re: Hemi Block Serial Numbers [Re: RestoreCuda] #268634
03/27/09 08:31 PM
03/27/09 08:31 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
There are only a few dist pad numbers on a '70 Hemi block, usually just the WT (water test) stamp and the assembly date.
The '66 and '67 had BH426 and CH426 stamps, the XH426 stamp was eliminated for '68 and up.
If no numbers at all exist, it's been decked.
It wasn't common for the dealer to restamp a VIN on a warranty block.
