70 Pymouth Body ID ?
#2678382
07/17/19 05:54 PM
07/17/19 05:54 PM
Posts: 781 usa
Mopar1970440
usa
Car in question is a Plymouth Satellite/Roadrunner shell, the car was used for parts...all bolt on sheet metal is gone and interior. Dash is gone, along with VIN plate, Data plate missing, and there is no title for the shell. It has the Big drum brakes and an 8 3/4 under it. Is there anywhere on the car to find a vin or partial VIN to tell what it was? I sanded down a part on the radiator support and I cant make the numbers out..but it looks like a date stamping almost? Thanks
Re: 70 Pymouth Body ID ?
[Re: a12rag]
#2678611
07/18/19 11:14 AM
07/18/19 11:14 AM
Posts: 781 usa
Mopar1970440
usa
VIN should be on rad support, on the cowl, and under the rubber seal on trunk side(s) . . . I can only make out a few numbers on the radiator support and it looks like there are dashes too so I was leaning toward that just being a date..? where on the cowl should I be looking? ill check into under the seal on the trunk Thanks
[Re: Mopar1970440]
#2678662
07/18/19 12:55 PM
07/18/19 12:55 PM
Posts: 8,409 Highland, MI.
Sunroofcuda
Highland, MI.
Driver's side rear quarter, under the weatherstrip. You are only going to get "BO123456" or not a "B" depending on where the car was made. We had the SAME scenario a few times back in the 80's at wrecking yards - one was a Moulin Rouge '70 GTX in TX, the other mystery car was a butterscotch 71 Cuda in CA. Never knew what either car had for drivetrain.
[Re: a12rag]
#2678714
07/18/19 02:44 PM
07/18/19 02:44 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
VIN should be on rad support, on the cowl, and under the rubber seal on trunk side(s) . . . No cowl VIN on B-bodies before the 1971 model year.
