what brand clutch to get. NP435 4 sp 143T wheel
#2670963
06/28/19 01:06 AM
06/28/19 01:06 AM
RapidRobert
65 D100. stock 400 BB. granny 4 speed. daily driver. what brand (part #'s if possible) should I order for the disc/pressure plate? thank you for your time.
Re: what brand clutch to get. NP435 4 sp 143T wheel
[Re: RapidRobert]
#2670996
06/28/19 07:43 AM
06/28/19 07:43 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
In trucks I used to run NAPA extra heavy duty remans.That was years ago and they worked well.Now in my 4 speed car I run Center Force dual frictions.Light pedal and hooks great.Rocky
Chrysler Firepower
[Re: therocks]
#2670999
06/28/19 07:46 AM
06/28/19 07:46 AM
RapidRobert
that was a NAPA reman plate/new disc? (I ain't a clutch guy).
[Re: RapidRobert]
#2671149
06/28/19 02:00 PM
06/28/19 02:00 PM
therocks
Niles , Ohio
Were both remans.Never bought new because remans were just as good for the usage.We also installed lots of clutchs from Advance in trucks at the shop.Some were new some remans.Depended on price difference.They worked good also.Rocky ,
Chrysler Firepower
[Re: therocks]
#2671220
06/28/19 04:31 PM
06/28/19 04:31 PM
RapidRobert
Sounds good. Thanks Rocky
[Re: poorboy]
#2671428
06/29/19 08:37 AM
06/29/19 08:37 AM
RapidRobert
I have a NAPA eng stand & I liked its stoutness & I need another one so maybe I will take care of both & Gene I will inquire about their "kit"
[Re: RapidRobert]
#2671601
06/29/19 02:47 PM
06/29/19 02:47 PM
RapidRobert
The NAPA guy could only find a kit for a 1969 D100 318: pressure plate/disc/throwout bearing/pilot bearing/alignment tool. Nothing for a BB app
[Re: Sniper]
#2671620
06/29/19 04:12 PM
06/29/19 04:12 PM
RapidRobert
He came up with 23 spline 5 springs push? diaphram 1" spline size 10-15/16 not sure what this is & shaft 11-1-16". he was just reading off info for what he was seeing on his 69 D100 (318) listing. I will see if I still have/can find the old plate/disc.
[Re: DusterJeff]
#2674038
07/04/19 02:03 PM
07/04/19 02:03 PM
Posts: 6,323 nowhere
Sniper
nowhere
Pretty sure the D100 RR is working on isn't going to use the same hydraulic setup as the 1990 you mention. That part has changed since then.
Is that NAPA guy reading off the computer?
If so tell him to get int eo books and look it up. But I bet it's the one you want anyway.
[Re: Sniper]
#2674174
07/04/19 06:28 PM
07/04/19 06:28 PM
RapidRobert
I bought the big block hyd bell/used plate/disc etc from a guy & it will be going into my 65D100 that has a /6 hyd clutch 3 speed. The problem is that the NAPA guy cant find an app for anything other than a 318 and I don't know the year/app of the stuff I bought from the guy (& I forgot who). I think I will take the plate/disc in & go from there. The kid really tried over the phone but I think this calls for a hands on visual.
[Re: 500ciDuster]
#2674409
07/05/19 12:25 PM
07/05/19 12:25 PM
RapidRobert
this is going in a truck that might not even be driven daily so likely I will go conservative. EDIT I counted the teeth on the flywheel & it is 186 teeth
