vibrations at 15-1900 RPM... #266685
03/25/09 10:30 PM
03/25/09 10:30 PM
Ormond Beach, FL
71STROKERFISH Offline OP
Ormond Beach, FL
Need to see if the vibration I'm feeling is coming from the engine/trans.
SB stroker I built 7 yrs ago
727 built 5 yrs ago
reinstalled freshened up torque convertor(teeth were chewed up). I missed the alignment dowel that was missing on the drivers side. Now after the reinstallation...I get a vibration in park,neural, drive etc. It's not a u-joint, it occurs any time you rev her up. It goes away after 1900ish rpm...
After I installed the convertor etc I took it on a 150 mile road trip. All highway, it drives like a dream until the last 10miles when I felt the vibrations.
What are the chances the lower end of the engine are in need of rebuilt...there might be 7k on the drive line.
I have checked for binds in the bellhousing, engine and transmision mounts .....trust me....this has been driving me nuts since late October.
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: vibrations at 15-1900 RPM... [Re: 71STROKERFISH] #266686
03/25/09 11:31 PM
03/25/09 11:31 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I don't understand the "missed alignment dowel" thing
Do you think it isn't lined up perfectly square with the engine?
I want my fair share
Re: vibrations at 15-1900 RPM... [Re: 71STROKERFISH] #266687
03/26/09 12:01 AM
03/26/09 12:01 AM
I would split the eng/trans, replace the missing dowel, pull the TC & check it for correct balance.
