Re: 1968 Charger....budget bomber
[Re: 70B5Cuda]
#2656574
05/18/19 01:40 PM
05/18/19 01:40 PM
Posts: 1,064 Newton, KS
70B5Cuda
Newton, KS
First thing that bugged me when I got home with it was the bent corner on the driver's side front corner where the inner fender meets the radiator support. It was still on the trailer when I did this last summer... View from the top looking down... I got an old 2x4 and a hammer/dolly and starting tapping away. It's not perfect, but I don't care...
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: 70B5Cuda]
#2660192
05/28/19 11:05 PM
05/28/19 11:05 PM
Superfreak
Superfreak
[Re: 70B5Cuda]
#2673434
07/02/19 11:41 PM
07/02/19 11:41 PM
Superfreak
Superfreak
You are certainly making progress. Keep up the good work.
[Re: 70B5Cuda]
#2677274
07/14/19 09:38 AM
07/14/19 09:38 AM
70B5Cuda
Newton, KS
Before I cut out the trunk floor, both rear frame rail needed patched near the top of the arch. Before aftermarket parts were available for these cars, someone had stripped this car. Apparently they really needed the shock absorber mount/crossmember, but instead of grinding welds to remove it, they used a torch. In the process they cut out sections of the frame rail. I didn't want to replace the whole frame rails so some sections were traced/cut and butt welded in. Before... After
[Re: CSK]
#2681794
07/27/19 12:26 PM
07/27/19 12:26 PM
70B5Cuda
Newton, KS
thanks CSK! I've been trying to find/buy a used rotisserie for the last 3 months and I can't get to one before its sold. I've emailed the seller within 2 hours of listing and it's always already sold. I told a friend and he said "why don't you just use mine?". I didn't even know he had one! So I picked it up and got the Charger mounted. Now I can cut out the trunk floor pan and remove the last of the undercoating from the rear frame rails.
[Re: 70B5Cuda]
#2684104
08/03/19 05:14 PM
08/03/19 05:14 PM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2689082
08/18/19 01:31 PM
08/18/19 01:31 PM
Superfreak
Superfreak
So I guess this is no longer a budget bomber??? Nice to have friends that will lend you things.
[Re: ]
#2689575
08/19/19 10:18 PM
08/19/19 10:18 PM
70B5Cuda
Newton, KS
So I guess this is no longer a budget bomber??? Nice to have friends that will lend you things. The scope ALWAYS creeps, but my goal is to keep this as budget oriented as possible. I'm not joking about doing a budget paint job either
[Re: 70B5Cuda]
#2690603
08/23/19 11:34 AM
08/23/19 11:34 AM
Superfreak
Superfreak
"Budget paint job".........Look at the paint job Pat did on his charger, I would class that as budget so if you set up like he did then you will have no worries at all. I will be painting my car as well and setting up a make shift booth in my garage. (22'-7"x 25'x 12'-2")
[Re: ]
#2690803
08/23/19 11:00 PM
08/23/19 11:00 PM
70B5Cuda
Newton, KS
"Budget paint job".........Look at the paint job Pat did on his charger, I would class that as budget so if you set up like he did then you will have no worries at all. I will be painting my car as well and setting up a make shift booth in my garage. (22'-7"x 25'x 12'-2") LOL. I'm not even close to being in the same league as Pat. Pat has more skills and patience then me. Mine will be a satin or patina job.
[Re: 70B5Cuda]
#2708649
10/20/19 08:07 PM
10/20/19 08:07 PM
Posts: 855 ontario canada kingston
aspenrt360
too bad so much got cut out it looks like it was a very solid car all in all. great work by the way i am going to get myself one of t hose needle scalers!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: 70B5Cuda]
#2767462
04/23/20 02:47 PM
04/23/20 02:47 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
I am following this with interest, as I love these years of the Chargers. You are doing a very nice job so far, keep up the good work. I am looking forward to seeing how this turns out. If you would like check out our build on a '66 Charger.
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
[Re: 70B5Cuda]
#2771900
05/06/20 07:35 PM
05/06/20 07:35 PM
70B5Cuda
Newton, KS
New rear crossmember and rear valance... New one piece trunk floor... fitting a lower patch...
[Re: UCUDANT]
#2782998
06/08/20 07:44 PM
06/08/20 07:44 PM
70B5Cuda
Newton, KS
Dang, Great job Thanks! After some straightening, the driver's side quarter panel end cap fits greats now. before and after... The driver's side quarter also had rust on in front of the rear wheel well. It was patched inside and out...
[Re: 70B5Cuda]
#2802628
07/29/20 07:15 PM
07/29/20 07:15 PM
Superfreak
Superfreak
Nice job on the dent. Did you hammer and dolly it out?
[Re: ]
#2803127
07/30/20 10:47 PM
07/30/20 10:47 PM
70B5Cuda
Newton, KS
Nice job on the dent. Did you hammer and dolly it out? Unfortunately there isn't any access from the back side so Zach welded studs on and the dent was pulled
[Re: 70B5Cuda]
#2819108
09/09/20 09:41 PM
09/09/20 09:41 PM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2820424
09/13/20 09:45 PM
09/13/20 09:45 PM
Superfreak
Superfreak
Way more valuable left as a 68. Sell your your 70's parts and the 68 and concentrate on the first one.
[Re: ]
#2910323
04/14/21 11:51 PM
04/14/21 11:51 PM
70B5Cuda
Newton, KS
Way more valuable left as a 68. Sell your your 70's parts and the 68 and concentrate on the first one. I think you are correct. I need to concentrate on finishing my 68 pro-touring Charger This Charger has been sitting in the corner for too long (since September!!). Between working fulltime, my 5 kids activities , and getting back into parting out modern SRT8's I've been busy. I finally tossed some suspension underneath the Charger, unstacked the shop. and hauled it in for its VIN inspection. I always do that as soon as I get a car...I just got distracted I guess.
