Help identifying OEM disc brakes
#2652424
05/05/19 10:46 PM
05/05/19 10:46 PM
Posts: 2,260 IL
furious70
IL
1. Spindles
2. maybe newer stuff?
3. 68 B Body
4. also 68 B body?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Help identifying OEM disc brakes
[Re: furious70]
#2652468
05/06/19 08:06 AM
05/06/19 08:06 AM
RapidRobert
I'm assuming you dont have any A or B brakes on a car that you can measure. You might get a distance from a horizontle line thru the CL of the lower bolt holes in the spindle up to the top hole & someone might be able to compare that # to what they have (just thinking out loud here).
[Re: furious70]
#2652470
05/06/19 08:12 AM
05/06/19 08:12 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
I am pretty sure the disc brake set ups for 67,68 and 69 B-bodies was the Bendix four piston caliper setup. This set up is slightly larger than the Kelsey Hayes four piston setup that I think was available on A-body disc brake option in 69. I think that same K-H setup was also on Mustangs of that era. In 70, I think Chrysler used the single piston caliper design you show in your pictures across the models.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: dragon slayer]
#2653252
05/08/19 05:16 AM
05/08/19 05:16 AM
Posts: 5,931 ohio
ruderunner
ohio
Last picture looks like fmj stuff to me.
Angry white pureblood male
[Re: Cuda340]
#2653553
05/08/19 11:54 PM
05/08/19 11:54 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
If the inner bearing journal diameter measures 1.25", the first and second pictures are '70-'72 B/E body stuff.
The last picture is '80 and newer F/M/J body.
