Re: Factory Stamped Rocker Arms?
[Re: BradH]
#2652681
05/06/19 05:03 PM
05/06/19 05:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
They both have an L and an R rocker.
the number stamped on them is usually that last two of the part number but I'll be danged if I remember the numbers anymore.
[Re: Supercuda]
#2652697
05/06/19 05:52 PM
05/06/19 05:52 PM
RapidRobert
SB: the OE ones have a pronounced L/R offset but I have some replacement SB ones from the dealer & the pushrod round recesses look "almost" centered (I was expecting the offset) & no numbers just a "X" on the horizontle oil deflector tab on the top side above the pushrod oil hole. Pedestal slot is a weak 7/8" long/strong 5/8" wide.
[Re: RapidRobert]
#2652700
05/06/19 05:55 PM
05/06/19 05:55 PM
Supercuda
About to go away
About to go away
up yours
SB: the OE ones have a pronounced L/R offset but I have some replacement SB ones from the dealer & the pushrod round recesses look "almost" centered (I was expecting the offset) & no numbers just a "X" on the horizontle oil deflector tab on the top side above the pushrod oil hole. Pedestal slot is a weak 7/8" long/strong 5/8" wide. Pretty sure you are either talking about magnum rockers or speaking chevy LA rockers don't have a slot. Or an oil deflector tab. I assume he's talking about LA rockers because if they were magnum rockers it'd be real obvious.
[Re: Supercuda]
#2652702
05/06/19 05:56 PM
05/06/19 05:56 PM
RapidRobert
You are correct brother, magnums. Too much going on upstairs! (too many projects).
[Re: mopars4ever]
#2652707
05/06/19 06:13 PM
05/06/19 06:13 PM
Supercuda
About to go away
About to go away
up yours
As are 3004716 and 3004717,
2536145 and 2536146
4095708 and 4095709
4100774 and 4100775
depending on the year. Probably a couple others too.
[Re: Supercuda]
#2652857
05/07/19 08:21 AM
05/07/19 08:21 AM
Posts: 2,255 New York
rarefish
New York
I had believed that the B/RB rockers were a little longer than the SB rocker arms. Can anyone confirm that there is a length difference between the two?
The ones that I have look at so far are stamped F2RT and F5LT and a few have a stamped triangle with a P in the middle.
[Re: rarefish]
#2652871
05/07/19 08:59 AM
05/07/19 08:59 AM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
The ones that I have look at so far are stamped F2RT and F5LT and a few have a stamped triangle with a P in the middle. Small block roughly 3.03"; big block 3.3".
[Re: vdriver]
#2654538
05/12/19 10:52 AM
05/12/19 10:52 AM
rarefish
New York
The ones that I have look at so far are stamped F2RT and F5LT and a few have a stamped triangle with a P in the middle. Small block roughly 3.03"; big block 3.3". Thanks... I was at a friend's shop yesterday who had a set of BB rocker arms and I also read 3.3" on them.
[Re: rarefish]
#2654583
05/12/19 12:34 PM
05/12/19 12:34 PM
Posts: 2,535 God's Country Maryland
GODSCOUNTRY340
Small block rockers are 3 1/16" end to end and big block are 3 5/16" for those that just want to measure with a tape measure.
