Rocker arm side clearance
#2652220
05/05/19 12:33 PM
05/05/19 12:33 PM
69cornetr/t
69cornetr/t
I put some Harland Sharps on some 240 trick flows. And have .004 rocker arm side clearance . Seems odd they move pretty freely, but. I thought this was unusual some are even less, anyone experience this? Probably going to machine .015 off the spacers
Re: Rocker arm side clearance
[Re: ]
#2652264
05/05/19 01:48 PM
05/05/19 01:48 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
They are what they are.
Make adjustments as necessary.
[Re: Dave Hall]
#2652367
05/05/19 07:11 PM
05/05/19 07:11 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would be OK with .005 or .006. Don't want them sloppy loose, don't want them tight either. I spent the time making them all equal and centered on the valve.
