Six Pack Fuel Lines
#2652300
05/05/19 03:49 PM
05/05/19 03:49 PM
Posts: 3,684 South San Francisco, Ca
70sixpkrt
Who sells the best fuel lines that don't leak? My ends are starting to round out and I'm looking for a new set. My fuel lines currently don't leak.
Re: Six Pack Fuel Lines
[Re: 70sixpkrt]
#2652343
05/05/19 06:01 PM
05/05/19 06:01 PM
70duster340
[Re: DAYCLONA]
#2652400
05/05/19 09:14 PM
05/05/19 09:14 PM
70sixpkrt
I've used nothing but FineLines stainless steel 6 pack fuel lines over the years on several vehicles, zero leaks, just remember to use the correct fuel line wrenches, and put a lubricant on the threads before tightening any lines Thanks. I always use the correct fuel line wrenches but taking them off and on for fine tuning for 15 years they are rounding off.
[Re: 70sixpkrt]
#2652626
05/06/19 01:48 PM
05/06/19 01:48 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I always use a small dab of bearing grease on the threads.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2652736
05/06/19 07:50 PM
05/06/19 07:50 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
I always use a small dab of bearing grease on the threads. Why ?
[Re: Cab_Burge]
#2654120
05/10/19 06:51 PM
05/10/19 06:51 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Have you ever tried taking those lines off? At least one seems to get stuck every time. I think I might try bearing grease myself next time
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2654142
05/10/19 07:57 PM
05/10/19 07:57 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Have you ever tried taking those lines off? At least one seems to get stuck every time. I think I might try bearing grease myself next time If you want to make it real easy,flare a piece of 5/16 copper tubing,cut off the flare and insert in fitting,you'll only need one wrench to remove and you'll never have any leaks !!!
[Re: 62maxwgn]
#2654150
05/10/19 08:33 PM
05/10/19 08:33 PM
70sixpkrt
Have you ever tried taking those lines off? At least one seems to get stuck every time. I think I might try bearing grease myself next time If you want to make it real easy,flare a piece of 5/16 copper tubing,cut off the flare and insert in fitting,you'll only need one wrench to remove and you'll never have any leaks !!! Do you have a picture for an illustration?
[Re: 70sixpkrt]
#2654163
05/10/19 09:05 PM
05/10/19 09:05 PM
62maxwgn
Blair County,PA
Have you ever tried taking those lines off? At least one seems to get stuck every time. I think I might try bearing grease myself next time If you want to make it real easy,flare a piece of 5/16 copper tubing,cut off the flare and insert in fitting,you'll only need one wrench to remove and you'll never have any leaks !!! Do you have a picture for an illustration? Not really,just cut off the flare,put in the fitting,screw in nut and you're done. Maybe this will explain.A little more than involved than necessary but same principal but cutting off the flare is a little easier. https://www.youtube.com/watch?v=u7WULLs2nV8
