Re: Unbend a rim? [Re: Sunroofcuda] #2651441
05/03/19 02:42 AM
05/03/19 02:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Search YouTube for videos on fixing bent alloy rims and rims with excessive runout. They use dial indicators and heat with a jack.
Re: Unbend a rim? [Re: kentj340] #2651480
05/03/19 09:16 AM
05/03/19 09:16 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
I just realized I had bent one of my rims on the inside after taking it off to bleed brakes/general suspension inspection. Took it to a shop and they say they heat it before anything to prevent the aluminum from cracking. $135 + $65 if it needs to get re polished after the heat assuming it can be. Illinois blows.
