Re: Build share
[Re: HardcoreB]
#2959469
08/31/21 12:54 PM
08/31/21 12:54 PM
Posts: 4,673 On the parachute mount
n20mstr
Looks Awesome! Whats your geuss on weight? Mine was 3100 lbs with me in it. I HOPE less than 3000 WITH me but it's probably going to be nearer your weight Bob. Anyone want to guess??? I have MF tube front/coil overs, light brakes all corners, fglass dash, 2x3 rear clip 4-link and all assoc. brackets anti-roll Dana tube floors glass hood bumpers and decklid, 10gallon cell, Dbl beadlocks 10x33.5 M/T, 40 spline gun-drilled, Std 78 case 12V battery in rear. Tube steering column, ALL windows are lexan .125", 8.50 cert cage, mid-plate, PG trans with JW bell... I probably weight 150/160ish Mine is 3009 with me in it, ready to race. I would think you would be lighter
....BAD A$$ STREET CAR.....
Re: Build share
[Re: Al_Alguire]
#2959501
08/31/21 01:48 PM
08/31/21 01:48 PM
Posts: 4,045 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Looking great. Glad to see you got it moving under its own power this past weekend. Love to hear what you found with the 7530 box. Cant wait to hear how things go at the track. Best of luck!! Oh yeah mine weighed 3470 with me in it, all steel(except bumbers and hood), all working glass, dana 8.50 MS cage and full interior. Im not exactly the smallest guy either Thanks again. I tried swapping the polarity and it wouldn't even try to fire, back it went. Once i was able to get into programming...I found nothing (that I would recognize) which would retard the timing UNDER 800 rpm. So i just bumped it forward about 10? deg on the pick-up so i could take it around. I did readjust all RPM limits and i took out the 'start retard' which was only 8* also it looked like it had some downtrack/run retards on a graph (dots) that were about 8* so i moved the dots to 0. I havent checked it since those changes, maybe i did find something? Thanks again Tony! I acually weigh 205 so I'm starting to think it'll be close to where you are because the 4link backhalf is 2x3 and all related junk that i prob wouldnt need if it were ladder-bar. It's gotta be 75lbs heavier that a tube back ladder-bar. I don't think I'll be able to scale it before I do test and it kinda is what it is for now. I really would be curious to know how aggressive i can go anti-squat on this set-up. It's sitting at about 37" and 11"!!! showing 179% antisquat. If i move the lower bar up at the axle it'll put it at 41" and 10" with a.s. being 146%...anyone?
Re: Build share
[Re: Jeremiah]
#2959883
09/01/21 12:34 PM
09/01/21 12:34 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Gotta start somewhere with the 4 link. A thousand options and only a few are right for your car I would think thats a bit high and short but would need alot more info really, like HP, SLR, Weight, ride Ht, crank centerline, bar spread blah blah blah Also depends on your goal with the car, ride the bars for the fans or get down the track.
Re: Build share
[Re: Al_Alguire]
#2959956
09/01/21 03:59 PM
09/01/21 03:59 PM
HardcoreB
Shelby Twp. Mi
Gotta start somewhere with the 4 link. A thousand options and only a few are right for your car I would think thats a bit high and short but would need alot more info really, like HP, SLR, Weight, ride Ht, crank centerline, bar spread blah blah blah Also depends on your goal with the car, ride the bars for the fans or get down the track. It isnt much lower than a typical BB A-body in the front with a 26" tire so, 12"? It has about 1* rake towards the front. the cam c/l is about 18/ SLR IS 8.75/ HP750/ weight w/dr. 3000/ bar spread is about 10.5 rear and 6 front. There is a pretty quick lower bar change I will make and that'll get me 46" and 10". Which shows a 131 a.s. I'd like to get down the track fast with minor drama.
Re: Build share
[Re: JERICOGTX]
#2960156
09/01/21 10:46 PM
09/01/21 10:46 PM
Posts: 4,068 Mo.
racerx
Mo.
I like these build pics threads....I always steal one or two ideas..LOL
Agreed. Wish more people would share build threads. x3 alot to be learned in these build threads Very talented gents here.
Re: Build share
[Re: HardcoreB]
#2960923
09/04/21 11:04 AM
09/04/21 11:04 AM
Posts: 20,166 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks again guys! I had it out last night to shake out any obvious bugs in an undisclosed area with help from Gdemon, Dartin and my wife Michelle and thanks to Al for taking a quick tech call as well. There are a couple vids on Facebook. It seems to be working pretty well! I never drove anything this quick but, I felt pretty comfortable pretty quickly. Good to hear you got out. I’m sure after working on it that felt good.
Re: Build share
[Re: HardcoreB]
#2960949
09/04/21 12:15 PM
09/04/21 12:15 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
How about a face book link please ?
Re: Build share
[Re: Cab_Burge]
#2960977
09/04/21 02:38 PM
09/04/21 02:38 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
That is a very nice piece you've put together! Nice work. It's gonna ride real good!
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Build share (Vids added)
[Re: HardcoreB]
#2961108
09/04/21 11:54 PM
09/04/21 11:54 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
You might have to make the videos public, I can’t see them and am dying to!
[Re: Blusmbl]
#2961146
09/05/21 07:32 AM
09/05/21 07:32 AM
Posts: 9,828 MI, usa
dvw
MI, usa
