challenger SE vinyl top trim...different?? #1019905
06/24/11 08:47 PM
06/24/11 08:47 PM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Hello,
For several months I've been beating my head against the wall looking for the vinyl roof trim for a 70 Challenger SE. I've been lead to believe that the SE trim is 3/4" wide while the regular vinyl roof trim is only 1/2" wide. I've also been told that the SE trim mounts in a different location. Every once in a while I run across someone with trim for a standard challenger, but I've had no luck whatsoever on the SE trim.
Can anyone definitively state that the trim is, indeed, different between the two models? Also, is anyone aware of any company planning to repop this trim?
Thanks,
Danan
Re: challenger SE vinyl top trim...different?? [Re: Danan] #1019906
06/24/11 09:36 PM
06/24/11 09:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
roof mouldings per '70-'71 Parts Catalog
1970
Barracuda - BH23, 'Cuda - BS23, Gran Coupe - BP23 (w/vinyl top & two-tone) = 3419782/3419783
Challenger - JH23 (w/vinyl top & two-tone) = 2965408/2965409
Challenger R/T - JS23 (w/vinyl top & two-tone) = 2954408/2954409 I'll "assume" typo
Challenger SE - JH29, Challenger R/T SE - JS29 (w/vinyl top) = 3514058/3514059
1971
Challenger - JH23, Challenger R/T - JS23 w/o A78 (w/vinyl top & two-tone) = 2965408/2965409
Challenger - JH23, Challenger R/T - JS23 w/A78 (w/vinyl top) = 3620506/3620507
Was NOT expecting to find different part numbers '70 SE VS. '71 A78!!
Re: challenger SE vinyl top trim...different?? [Re: 6bblgt] #1019907
06/24/11 10:57 PM
06/24/11 10:57 PM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Great info; thanks 6bblgt!
But wow...that's worse than I suspected. The follow-on questions:
What's different about all these p/n?
Is there any reasonable amount of interchangeability between them?
Assuming the trim isn't NOS in the wrapper, how would you know what you're looking at if you picked it up at a swap meet?
I'm really wishing that this car were just a regular R/T!
Re: challenger SE vinyl top trim...different?? [Re: Danan] #1019908
06/25/11 12:35 AM
06/25/11 12:35 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I've seen a width measurement comparison between S/E and regular Challenger trim. Just search around more on the net.
IIRC, there were picture diagrams even.
Re: challenger SE vinyl top trim...different?? [Re: autoxcuda] #1019909
06/25/11 09:44 AM
06/25/11 09:44 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
didnt know they were different eiher, I always thought it was 70-71, then 72-74
Re: challenger SE vinyl top trim...different?? [Re: Danan] #1019910
07/04/11 06:29 PM
07/04/11 06:29 PM
Montgomery, Alabama
RusTy/SE Offline
RusTy/SE  Offline
Montgomery, Alabama
I have this as a reference photo to go by just before I hit the swap meets
Re: challenger SE vinyl top trim...different?? [Re: Danan] #1019911
07/05/11 12:07 PM
07/05/11 12:07 PM
cataclysm80 Offline
cataclysm80  Offline
Yes, the SE trim is different from the standard vinyl top trim.
Also, the SE trim mounts a little further down from the back window I believe.
Tav
Re: challenger SE vinyl top trim...different?? [Re: 6bblgt] #1019912
07/05/11 12:13 PM
07/05/11 12:13 PM
cataclysm80 Offline
cataclysm80  Offline
That IS interesting. I hadn't considered that the A78 trim could be special. I won't know without looking at one, but I suspect the difference is probably in the clips that hold the trim in place. Those part #'s may be for the trim WITH the clips.
The T/A hood trim is the same as a regular challenger, but the retainers for the T/A are different, so the T/A trim uses a different part #. I suspect the SE vs A78 is a similar situation.
Tav
Re: challenger SE vinyl top trim...different?? [Re: cataclysm80] #2646312
04/18/19 02:22 AM
04/18/19 02:22 AM
Ohio, USA
P
PlumCrazyRTSE Offline
P
Ohio, USA
Tav
Actually, the SE trim mounts further up towards the back window.
Re: challenger SE vinyl top trim...different?? [Re: PlumCrazyRTSE] #2646322
04/18/19 05:52 AM
04/18/19 05:52 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Does anyone have some 71 A78 trim?
Be interesting to see the difference.
