vert top frame finish ? #2629863
03/07/19 06:52 AM
03/07/19 06:52 AM
Southeast PA
5wndwcpe Offline OP
5wndwcpe  Offline OP
Southeast PA
'68 Plymouth B body convertible - what is the correct finish on the top frame ? I have two of them in the shop and both seem to have a satin (to maybe once, 80% gloss) black paint on them. There is no evidence of any other finish, even under the weatherstripping channels EXCEPT the small metal piece that holds the w/s under the header bow. This piece is gloss black. It seems odd they would paint this piece and this piece only differently.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: vert top frame finish ? [Re: 5wndwcpe] #2629942
03/07/19 12:01 PM
03/07/19 12:01 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 68 Dart sat for years with the top down so it's probably not the best example. However, it looks like a semigloss finish. I was planning on using SEM Trim Black on it. It's a nice medium black. Not to glossy and not too flat. I think you can get Trim Black in in quarts so you can spray it with a gun. I'm curious what others use.
Re: vert top frame finish ? [Re: 5wndwcpe] #2636450
03/24/19 02:07 PM
03/24/19 02:07 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
Of the vert's I've had they were all a semi gloss finish, all a little different, they used gloss lacquer here but the gloss depends on how much it was thinned and how much applied. 67 Coronet, 69 Coronet, 63 Valiant, 66 Valiant, 65 Polara, two 67 Monaco 500 and two 68 Monaco 500. The small piece your talking of most likely just got more.
Re: vert top frame finish ? [Re: Ramtough] #2644920
04/14/19 08:06 AM
04/14/19 08:06 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Years ago when I replaced the original top on my 65 coronet it had white outside white underside. The Legendary replacement top came with a white outside black underside. I called them looking for double white top and was told this was all they offered. Then I called around to other company's , same thing. So I was forced to paint my all original top irons so things didn't look terrible.
