Re: total ignition timing
[Re: superbee471]
#2643340
04/09/19 05:50 PM
04/09/19 05:50 PM
Posts: 4,457 Washington
madscientist
Washington
You need to account for the amount of retard your ignition box has. You can't see it with a timing light, but it's there.
[Re: superbee471]
#2643350
04/09/19 06:06 PM
04/09/19 06:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
setting the ignition timing on a new 500 c.i. race b engine. engine has 12 to one compression, edelbrock rpm heads, hooker super comp. headers and holley 950 carb. set initial timing @12 to 13 degrees, with total all in at 2800 for a total of approx. 35 degrees. my question is will I gain any more by adding the 3 more degrees that I can get out of the MSD distributor, or is 35 total going to get me basicly what the engine is capable of ? the 440 I just took out ran its best with 35 total advance so used that to set new engine. any insights will be appreciated. You should re-do the timing curve and install more base and less on the advance.. still have about the same total
[Re: MR_P_BODY]
#2643363
04/09/19 06:34 PM
04/09/19 06:34 PM
Posts: 614 Michigan
Get-X
Yep, agree with the others here, I'm normally 20ish initial and 36ish total. It may vary slightly from engine to engine, but that will get you close.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: superbee471]
#2643472
04/09/19 11:23 PM
04/09/19 11:23 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Not all BB Mopar race motors like the exact same total timing, not all timing lights show exactly the same timing also, especially with race ignitions I would start with 34 degrees total, and do and then try 35 after the new motor is repeating times within .001 to .003 for 5 or 6 runs or more, then 36 and maybe even 37 and 38 to find out exactly what the new motor wants. Did you verify TDC on the balancer and timing tab? If not do that first before doing anything else If so proceed to testing at the track Let us know what you find works the best now
[Re: tubtar]
#2643485
04/10/19 12:29 AM
04/10/19 12:29 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
In at 2800 ? I like to get in in by 2200. Street or race , but every car I have owned that I was this particular about the timing with was driven with a heavy right foot and size 15 carbon footprint. I am using an MSD 6AL2 programmable now , and use the box to handle start retard and advance. Just write the curve how you want it , and forget about it. With a map sensor the boost retard can also be used!
[Re: hemi-itis]
#2643507
04/10/19 04:29 AM
04/10/19 04:29 AM
Posts: 4,647 aotearoa
rebel
aotearoa
As Cab said, not all motors react to the same timing. I have an alloy B block with -1 heads, single 4 bbl at 12.5:1 compression.. we start at 22* @1000rpm idle, the advance only kicks in at 5000 rpm where we jump to 38*. The brake launch rpm is 5500 rpm, the converter is 6700 rpm, we rev to 8k. The car runs 8.9@151 mph.Plugs look clean, bearings are still mint at rebuild time, never any sign of detonation. I do have a reverse flow water pump that might be the deciding factor.
