Re: Street stroker quench ??
[Re: Stanton]
#2642896
04/08/19 06:42 PM
04/08/19 06:42 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have and do currently run .030 on a SB without blinking an eye, I don't think you have anything to worry about as far as piston to head.
[Re: Stanton]
#2642900
04/08/19 06:51 PM
04/08/19 06:51 PM
Posts: 17,888 S.E. Michigan
ZIPPY
S.E. Michigan
Racers have successfully used Cometic gaskets with RA all over the map and copper coat For quite some time now. I realize it's not perfect and it's not recommended by the manufacturer, but sometimes You have to make do....
Rich H.
Esse Quam Videri
[Re: AndyF]
#2642920
04/08/19 07:40 PM
04/08/19 07:40 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
On my 512 low deck, I used the .051 Cometic with piston .016 out of the hole.
[Re: CSK]
#2643013
04/08/19 10:40 PM
04/08/19 10:40 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
You could probably shave a little off the tops of the pistons. The motor is fully assembled. Thicker custom head gaskets are the easy answer - if deemed necessary.
[Re: Stanton]
#2643018
04/08/19 10:47 PM
04/08/19 10:47 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
just ring Cometic and order the thickness you need . I have 0.040gasket for 0.040-0.042 quench in my 505 , I think i ran 0.037-.0.038 quench on my old 505
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Stanton]
#2643057
04/09/19 12:41 AM
04/09/19 12:41 AM
Posts: 31,050 Oregon
AndyF
You could probably shave a little off the tops of the pistons. The motor is fully assembled. Thicker custom head gaskets are the easy answer - if deemed necessary. Does the person who put the motor together with the pistons sticking out have any ideas on how to solve the problem?
[Re: Stanton]
#2643073
04/09/19 03:17 AM
04/09/19 03:17 AM
Posts: 43,233 Bend,OR USA
Cab_Burge
Go through and check all eight pistons at TDC and use a thin bladed screw driver between the tops of the pistons on the cam side and motor mount side to rock the pistons as far over as you can get them both ways and measure the piston height above the decks on the outer edges and go from there If you get .020 or less above the decks I would run it If it is above .022 or more get a thicker head gasket
[Re: sasquatch]
#2643136
04/09/19 09:48 AM
04/09/19 09:48 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Does the person who put the motor together with the pistons sticking out have any ideas on how to solve the problem? No he doesn't. It pisses me off that he didn't measure the deck heights and do some basic math before machining things. At some point he could have said it was going to be tight and I would have found another block.
[Re: bobby66]
#2643188
04/09/19 11:39 AM
04/09/19 11:39 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
How close is the top ring to the deck? Is there a bevel at the top of the bore? The difference between where the piston is supposed to sit at TDC (-.009) and where it is (+.016) is not enough to matter about the ring or bevel.
[Re: Stanton]
#2643221
04/09/19 12:58 PM
04/09/19 12:58 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Big bore, short piston........ I’d be shooting for around .050 piston to head clearance.
[Re: Stanton]
#2643370
04/09/19 06:57 PM
04/09/19 06:57 PM
AndyF
Does the person who put the motor together with the pistons sticking out have any ideas on how to solve the problem? No he doesn't. It pisses me off that he didn't measure the deck heights and do some basic math before machining things. At some point he could have said it was going to be tight and I would have found another block. Yeah that is a bummer. Typically I'd get a call from the engine builder saying "um, your block is a little short. What should we do". I'd be pissed if I showed up and the pistons were sticking out of the holes since now you have limited options.
[Re: 451Mopar]
#2643420
04/09/19 08:53 PM
04/09/19 08:53 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
KInd of had the same scenario with the R1 block in my car. When we put it together the pistons were out of the hole, machine shop forgot to say that the block needed a little more taken off to square it up. We were able to fix the issue with .056 cometic gaskets. I will say the cometic have worked great and I will re use them after this top end refresh.
68 Barracuda Formula S 340
