Standard vs. Reverse Rotation steering box? #2639206
03/31/19 03:07 PM
03/31/19 03:07 PM
Indiana
68_661charger Offline OP
Indiana
Im putting power steering on my 77 2wd Dodge truck. All of the steering boxes I see are for reverse or standard rotation. My pitman arm nut faces down. What do I need and can I use the manual pitman arm on the power box?
Re: Standard vs. Reverse Rotation steering box? [Re: 68_661charger] #2639262
03/31/19 06:24 PM
03/31/19 06:24 PM
Alberta
440_Offroader Offline
Alberta
You want the standard rotation steering box. The reverse rotation boxes are for 4wd and have the sector shaft come out the side. I think the 4wd boxes switched to standard rotation around '78ish. I believe all 2wd boxes were standard rotation. Not sure if the pitman arm will interchange or not, between manual vs power steering boxes.
Re: Standard vs. Reverse Rotation steering box? [Re: 440_Offroader] #2639276
03/31/19 07:08 PM
03/31/19 07:08 PM
Indiana
Indiana
Ok thanks!
