Re: Mystery PS Pump?
[Re: lewtot184]
#2634083
03/18/19 02:47 PM
03/18/19 02:47 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
It' is a Federal pump. With that mounting bracket on it, was used from 1969-72. big block engines. Since it's a "solid" pulley, and not a three spoke one, it could be a 426 Hemi pulley. If it is, good score.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#2635109
03/21/19 09:21 AM
03/21/19 09:21 AM
Posts: 2,252 New York
rarefish
New York
It' is a Federal pump. With that mounting bracket on it, was used from 1969-72. big block engines. Since it's a "solid" pulley, and not a three spoke one, it could be a 426 Hemi pulley. If it is, good score. Well, I have figured it out. It turns out to be of all things a Slant 6 power steering pump set up. Here it the same deal for sale on ebay. I also have the same "funky" looking pulley that goes on the crank. https://www.ebay.com/itm/Mopar-225-...lleys-Dart-Cuda-B-A-E-Body-/123655721255Maybe I will remove the brackets and pulley and just sell the Federal pump separately. Probably worth more that way.
[Re: rarefish]
#2635122
03/21/19 10:07 AM
03/21/19 10:07 AM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I believe I pulled a similar pump/pulley off a 1968 383. There was also a copy-cat federal pump, I think it was a TRW? One had adjustable or variable assist based on rpms, I don't remember which. I found it was hard to find a spoked pulley that wasn't bent which is why I swapped to the solid one. After several federal pumps puked their guts past 6000 rpm, I ripped it all off and went with a saginaw.
EDIT: If anyone buys cores for this stuff in the PA/NY/NJ area, send me a PM.
