Re: 8 3/4 Green Bearings, loose of tight?
[Re: NV69B7RR]
#2632447
03/13/19 09:54 PM
03/13/19 09:54 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
They are a ball bearing type bearing, not a tapered Timken tapered roller bearing like the stock types are. I would wrap my hand around the outer race and rotate the race against the bearings for several revolutions and see if you can feel any rough or tight spots If so replace them
[Re: Cab_Burge]
#2632450
03/13/19 10:00 PM
03/13/19 10:00 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I do believe those are sealed bearings. If so, what you are feeling is the rubber seal. As stated, after some run time they get looser.
