Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2924193
05/19/21 12:24 AM
05/19/21 12:24 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Holy cow...I have that exact same Hoppy alignment system (arrow on right in garage fire photo). I just got done cleaning that up a few weeks back.
Also have an earlier unit in the wooden box (arrow on the left).
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: new project 1966 Hemi Coronet 500 [Re: DynoDave] #2924289
05/19/21 10:58 AM
05/19/21 10:58 AM
tennessee,usa
mattsmopars Offline OP
tennessee,usa
It took me a little time to figure it out, but as of now i am very surprised how well it seems to have worked.
Matt
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2931265
06/08/21 01:23 PM
06/08/21 01:23 PM
tennessee,usa
tennessee,usa
Like everything in life we all have a learning curve. I purchased the right stuff rear disc brake kit that uses the GM metric rear calipers, and saw a topic on here about needing to adjust the E brake lever to limit travel, then bleeding the rear calipers. So I got those things done and that caused another issue. The kit originally came with two equal length E brake cables, but the 66 coronet does not use that type of set up and I didn’t want to modify the car. I called “The Right Stuff” about the issues and they said to order and use a set of the original drum brake emergency cables, so I did. Once those were installed the drivers cable was always short, but worked with a bracket that I had made/modified to help with the different lengths of the two cable ends. Once I adjusted the E brake arms though the cable would pull the E brake by just setting the car on the floor. So I called them back and the suggested to call Control Cables out in California. I have to give them credit they sent me a diagram to use and measure what was needed, also put an adjuster on the frame bracket side to fine tune any difference in length and it worked out great. I’d suggest them if you have any needs for different cables. The first two pictures are the original drum brake style cables and the last two are the new E brake cable installed from control cables.
Matt
4389EB39-BD86-4EB9-BDE7-966507994A10.jpeg45634B58-5F92-49B6-85A8-0237D7924895.jpegC2064028-6EC1-4548-986D-99CB2F44E548.jpeg63502759-7BEF-4E79-BE57-6625AAFE73F9.jpeg
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2933394
06/14/21 10:47 PM
06/14/21 10:47 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The sounds coming out of those tail pipes pure awesome! Going to be something when you get it on the road shifting that 4 speed. Wow!
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2941664
07/09/21 09:23 PM
07/09/21 09:23 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
looks awesome.
the wheels look like VN309 so probably 15x5 with 2.76 backspacing. is that right?
Which tires are on the front?
Re: new project 1966 Hemi Coronet 500 [Re: krautrock] #2944983
07/19/21 10:08 PM
07/19/21 10:08 PM
tennessee,usa
tennessee,usa
Originally Posted by krautrock
looks awesome.
Your correct on the wheels and tires are repro BFG.
Matt
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2950217
08/03/21 09:56 PM
08/03/21 09:56 PM
tennessee,usa
tennessee,usa
Removed the original rear trim panels from the car, used some SEM die to redo the carpet and just cleaned the vinyl parts up. Also buffed the upper painted portions. I will post some pictures of the trim panels and some of the original vapor barriers and other items. The rear trim panel look to be dated March 22 1965, which is a little strange being as the car is SPD of 4-66.
Matt
D6E07E30-E3E0-4AD2-A932-5011617291E9.jpegF6A6070B-1770-4BCD-8A76-53BF11DF475D.jpeg996C0664-9802-45D8-9720-FBEF6BBBC11F.jpegF44AF878-8E57-41DC-B6FA-D74F752A8368.jpeg
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2950223
08/03/21 10:03 PM
08/03/21 10:03 PM
tennessee,usa
tennessee,usa
Wanted to also post a few pictures of the original vapor barriers and the package tray and insulation that was under the package shelf cover.
3D7DD679-EEBB-49AA-9001-DD044D57BF02.jpeg80D9FAD8-3ED1-4082-94AF-79CB099C0DD3.jpeg927050A0-FC86-41EC-877B-E72120B6060B.jpeg
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2950227
08/03/21 10:09 PM
08/03/21 10:09 PM
tennessee,usa
tennessee,usa
A few from the other day when I was able to get it out and drive it.
Matt
E3978AE4-9716-4051-BD40-581039A5BFB0.jpeg01257519-3223-4D0D-A259-BCCAF9D4F9C7.jpegFB6D544B-2C35-493D-8E23-DFA675CAE69D.png393FE4AD-7EE4-4AE1-870B-FF9A876A911E.jpeg
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2950296
08/04/21 08:36 AM
08/04/21 08:36 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Well done !!! up
Troy
Houston Mopar Connection Club
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2950510
08/04/21 08:06 PM
08/04/21 08:06 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
looks good
Re: new project 1966 Hemi Coronet 500 [Re: gtx6970] #2962418
09/09/21 09:53 AM
09/09/21 09:53 AM
tennessee,usa
tennessee,usa
I was able to get the car out this past Monday and put about 40 or so miles on it. For the most part fairly uneventful until the drivers side front caliper cooper washer decided to leak. Thought I’d post a couple pictures.
Matt
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #2962863
09/11/21 08:55 AM
09/11/21 08:55 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
that looks great!
1981 Dodge D150 360 auto
Re: new project 1966 Hemi Coronet 500 [Re: basketcase] #2979606
10/29/21 01:44 PM
10/29/21 01:44 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Matt I just found this thread! Congrats on a job well done! What a great feeling!
Re: new project 1966 Hemi Coronet 500 [Re: dmoore] #2979896
10/30/21 01:08 PM
10/30/21 01:08 PM
It's a dry heat
It's a dry heat
Ive never been a big 66-67 Coronet fan.
But the color, drive train along with the tires and wheels combination makes this car look killer.
I love it
Re: new project 1966 Hemi Coronet 500 [Re: dmoore] #2980510
11/01/21 11:06 AM
11/01/21 11:06 AM
tennessee,usa
tennessee,usa
Thank you David.
Matt
Re: new project 1966 Hemi Coronet 500 [Re: gtx6970] #2980511
11/01/21 11:08 AM
11/01/21 11:08 AM
tennessee,usa
tennessee,usa
I love it
Thank you, It has been a frustrating build at times, and i still have a decent amount to do. We will keep working, and thanks for the kind words.
Matt
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #3143181
05/08/23 12:02 PM
05/08/23 12:02 PM
tennessee,usa
tennessee,usa
I have been doing a little bit along on the coronet. Not making the progress that I was a couple years back but still progress. I thought I’d add some pictures of the drivers door panel area I have been working on. Just some original details that seem to get lost when a car is restored.
Matt
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #3143182
05/08/23 12:03 PM
05/08/23 12:03 PM
tennessee,usa
tennessee,usa
Some of once the trim panel was cleaned up, the carpet dyed and glued back down. Next for arm rest and bases to install. Also one picture of it when I had it out the other day.
Matt
Re: new project 1966 Hemi Coronet 500 [Re: mattsmopars] #3144039
05/11/23 10:23 PM
05/11/23 10:23 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Nice work. up
DynoDave
Member # 12304
