Re: What ignition systems r u running 383 other than Mopar-MSD [Re: NANKET] #2629063
03/05/19 11:08 AM
03/05/19 11:08 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted By NANKET
Originally Posted By Supercuda
I still run points.
Nothing simpler, nothing easier.
Works fine if you maintain them.
The best ignition upgrade a guy could do! I’ve swapped all my cars back to points. Never been walking with points. 3 times stranded with the other “upgrades” Maintenance is the key, and if you drive a few thousand miles a year then the maintenance is a quick look. Thanks.
Anybody in the market for a MSD box and B engine distributor?
I think if I had two good prestolite distributors i'd ditch all the electronics.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: Black 69 Beeper] #2629065
03/05/19 11:15 AM
03/05/19 11:15 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Jacobs was good stuff. Dr. Jacobs actually invented the multi-spark discharge but I believe he sold the rights to Autotronics (MSD). I still have a Jacobs pro-street box laying around. years back I talked many times to the Jacobs tech's and they told me the multi-spark capacity discharge was designed to fix GM HEI issues. the last I heard on MSD boxes is they have a 25% return rate due to problems.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: Black 69 Beeper] #2629093
03/05/19 12:26 PM
03/05/19 12:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Jacobs did not invent the multi spark discharge ignition. That probably predates his birth. Earliest patent I can find that references more than one spark per ignition event was issued in 1939. It was both tube based and a non-contact electronic ignition system.
Don't be the exception.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: Supercuda] #2629127
03/05/19 01:32 PM
03/05/19 01:32 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I'm surprised so many prefer points. up
That was the first lesson I learned on maintenance.
Still run points on the stuff I have that came with 'em.
Still have no problems with factory electronic stuff either.
Knock on wood.
I have mechanical Aptitude.
I can screw up anything.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: bboogieart] #2629134
03/05/19 01:41 PM
03/05/19 01:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Points have the virtue of being cheap, easy and obvious.
electronic stuff isn't.
The factors that drove the OEM's to electronic ignition setups do not apply to me.
Do I have to worry about emissions? nope
Do I have to worry about economy? nope
Do I have to worry about a 50,000 mile warranty? nope
If my points fail I can usually fix them with whatever I have in my pockets. I cannot do that with electronic stuff and I have been fixing electronic stuff for 35 years.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: Supercuda] #2629140
03/05/19 01:48 PM
03/05/19 01:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I always carry a fingernail file and a matchbook.
Have had to use 'em on occasion. Surprises some folks a bit.
I think having to maintain them is the reason folks don't use 'em.
Same reason fuel injection swaps are becoming more and more popular.
I happen to be in the same position as posted above.
Emission, nope
Economy, nope.
Warranty nope.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: Supercuda] #2629168
03/05/19 02:34 PM
03/05/19 02:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
ok. maybe I should have said the first marketable capacitive discharge for the aftermarket auto world. slice and dice but it's my understanding that there wouldn't be an MSD box without Jacobs.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: bboogieart] #2629169
03/05/19 02:35 PM
03/05/19 02:35 PM
Here and now
jeebis44 Offline
jeebis44  Offline
Here and now
What was the advantage of dual points over the single points?
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: jeebis44] #2629176
03/05/19 02:37 PM
03/05/19 02:37 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Longer duration = hotter spark.
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: jeebis44] #2629177
03/05/19 02:37 PM
03/05/19 02:37 PM
Here and now
jeebis44 Offline
jeebis44  Offline
Here and now
Also, in his book Dr. Jacobs mentions a nifty little device he came up with and sold for a while consisting of a dash-mounted unit that allows you to fine tune the ignition timing for different gas / driving conditions. That sure would be nice to have...
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: jeebis44] #2629185
03/05/19 02:45 PM
03/05/19 02:45 PM
^^^ I got one of those (still on the shelf tho). In the Jacobs bible he has top notch info on maxing out points, (2 condensors in series & more). I liked useing 2 batteries & giveing 24 volts during WOT then in the corners you let off & it goes back to 12V & things cool. We cant use 2 batteries so that mixes that (for me). EDIT on a points dist, confirm the bushings/shaft radial play at the top (where the points are) is minimal (new bushings if needed) & shim the lower shaft end play to .005" (speedway mtrs has a kit of (5) shims for cheap).
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: TJP] #2629936
03/07/19 11:52 AM
03/07/19 11:52 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted by TJP
Originally Posted by RJS
I have never used an MSD in any car I've owned in the past 42 years. I've run the MP distributor with a stock box or a chrome box recurved and dialed in even in a 10 second street car.
On the car's that came with stock dual points I then used Pertronix conversions in them and all was well also.
Ron
iagree
And will Add the simplicity of troubleshooting along with the availability of parts is another big plus IMO
beer
What’s more simple than MSD box? Also no parts are needed when they don’t fail the MSD 6AL box in my Demon is at least 20 years old. If you’re speaking of caps and rotors well if you aren’t keeping a spare with you at all times then that’s your fault.
(You’re, your and you are directed as generalizations not at anyone in particular so that no one gets butt hurt)
eBay-cdwmotorsports
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: cdwmotorsports] #2629969
03/07/19 01:13 PM
03/07/19 01:13 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
considering the car wiring and engine bay locations are ready for the stock unit... A PERFORMANCE UNIT FITTING JUST LIKE ANY STOCK replacement is WAY easier LOL.
aaand I already have got two friends with damaged MSD Box &/or RTR MSD dist. Being overseas, thats a headache!
and about the YOU note... that's a problem we don't have in spanish, because we have two diff "you", one for single and one for plural LOL
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: Black 69 Beeper] #2630625
03/09/19 12:39 AM
03/09/19 12:39 AM
hickory nc USA
skyhawk61 Offline
skyhawk61  Offline
hickory nc USA
Running a set of NORS Sorensen cross-cut high performance points and condenser in a '68 Chrysler distributor. Chrysler/ or aftermarket electronic boxes (insert color here, orange, black, chrome,etc) have left me walking too many times. I can fix a point/condenser problem on the road quickly, cheaply. Thousands of miles and so far no issues
Re: What ignition systems r u running 383 other than Mopar-MSD [Re: NachoRT74] #2630683
03/09/19 10:41 AM
03/09/19 10:41 AM
moparx Online content
moparx  Online Content
you forgot Yunz, You'ns, Youse, Yinz, and Yizens. biggrin
beer
