Re: Teflon ape on fuel line fittings
[Re: robertop]
#2625182
02/23/19 06:48 PM
02/23/19 06:48 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I might be just full of bull, but I seem to remember reading somewhere that you don't use teflon tape on fuel line fittings, and the reason escapes me. Do you think this is only rubbish? I would never use teflon tape on fuel fittings. If it breaks off (including during removal) it can plug up small orifices in the fuel system including the carb. A good sealant (I use Loctite PST teflon sealant) is recommended.
[Re: robertop]
#2625220
02/23/19 08:48 PM
02/23/19 08:48 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I use liquid Teflon sealer on all my pipe thread fittings. Just a dab on the clean dry threads and you will be leak free. You can get it from any parts store or even the hardware stores carry it. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: mopargem]
#2625237
02/23/19 09:49 PM
02/23/19 09:49 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
If you were to use teflon tape, it needs to be the yellow type which is resistant to fuel Yellow Teflon tape is designed for natural gas and propane lines, not gasoline.
[Re: Pacnorthcuda]
#2625248
02/23/19 10:05 PM
02/23/19 10:05 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
If you were to use teflon tape, it needs to be the yellow type which is resistant to fuel Yellow Teflon tape is designed for natural gas and propane lines, not gasoline. White for liquid gasoline or diesel OP, do NOT use any sealant on any AN fitting other than the NPT ends
[Re: Pacnorthcuda]
#2625274
02/24/19 12:08 AM
02/24/19 12:08 AM
Posts: 3,378 KY USA
mopargem
KY USA
If you were to use teflon tape, it needs to be the yellow type which is resistant to fuel Yellow Teflon tape is designed for natural gas and propane lines, not gasoline. Oh no my bad sry. I’ve beem wrong all these years
[Re: mopargem]
#2625317
02/24/19 03:29 AM
02/24/19 03:29 AM
Posts: 8,396 Highland, MI.
Sunroofcuda
Highland, MI.
If you were to use teflon tape, it needs to be the yellow type which is resistant to fuel Yellow Teflon tape is designed for natural gas and propane lines, not gasoline. Oh no my bad sry. I’ve beem wrong all these years Good thing you never had a 'splosion!
[Re: iapco103]
#2625910
02/25/19 04:14 PM
02/25/19 04:14 PM
Cab_Burge
GM used white Teflon tape for years on Q-Jet fuel inlets, not as a sealant, but as a friction reducer, it allowed the flare nut to be tightened sufficiently without rounding the flats. Paul If GM had flared the fuel line carb end properly they wouldn't have needed to do that
[Re: Cab_Burge]
#2626087
02/25/19 10:31 PM
02/25/19 10:31 PM
Posts: 15,372 Omaha Ne
TJP
Omaha Ne
