Bge crank #2624817
02/22/19 06:04 PM
02/22/19 06:04 PM
Texas
0
03heavy Offline OP
03heavy  Offline OP
Texas
I’m thinking about taking a bge 6.4 and just replacing the pistons and rods
With a forged high compression piston roughly 13-1
Along with a decent rod
Carbed the engine and use it in my index car
Any reason not to use the factory crank ??
Re: Bge crank [Re: 03heavy] #2624847
02/22/19 07:34 PM
02/22/19 07:34 PM
USA
hudsonhornet7x Offline
USA
I am a fan of the factory cranks from the 6.4 They have proven themselves in forced induction applications to over 1,000 hp.
Re: Bge crank [Re: hudsonhornet7x] #2624874
02/22/19 08:42 PM
02/22/19 08:42 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
…. 1,000hp crank or wheel? and if so how much more have you seen?
Re: Bge crank [Re: 03heavy] #2624951
02/23/19 12:29 AM
02/23/19 12:29 AM
USA
USA
1,000 hp wheel. Give David Weber a call from modern muscle xtreme. He will fill you in on what they can take. In fact, he collaborated with Hot Rod not too long ago and used a stock 6.4 bottom end ( albeit with his drop in rods and pistons) and it made 1,000 on the dyno with I believe stock main bearings, bolts, etc.
Re: Bge crank [Re: 03heavy] #2625376
02/24/19 12:04 PM
02/24/19 12:04 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
No, as long as it doesn't starve for oil(IE Oil pump caveats) you'll lift the heads on a BGE before you hurt the crank.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Bge crank [Re: 03heavy] #2627194
02/28/19 06:32 PM
02/28/19 06:32 PM
IL
Dart451 Offline
Dart451  Offline
IL
