Re: SB oil pump/pressure question
[Re: StrokerPost]
#2623253
02/19/19 11:40 AM
02/19/19 11:40 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
chunks of nylon from the timing gears have been known to do this exact thing. The nylon flakes off over time, the pick sucks it up tot eh pickup screen, flow is cit off, you shut down and the flakes float away only to do it again later.
I suppose a sticky bypass in the pump itself could do it too
[Re: StrokerPost]
#2624515
02/22/19 12:26 AM
02/22/19 12:26 AM
RapidRobert
As said I would suggest changeing the filter first. EDIT then I would take off/check/clean the 90 deg filter adapter if it has one on your app. then I would preoil with it still off & see if it gushed out the hole especially if you can preoil it at a time when it has zero psi & all that is left is the pickup plugged (likely at that point) or pump bypass. I'm thinking clogged pickup but holler what it ends up being. With a flat circular plate you might also preoil it & see if it flows out the small holes. Actually I would grab a helper & have him undo the filter/plate/bypass while you are preoiling & do this at a time when it is showing zero psi, anything to avoid pulling the pan if you dont have to tho I ain't thinking of anything up top that would make this intermittent once it makes the horizontle turn back to the vertical feed.
