Toe Issue
#2623430
02/19/19 08:09 PM
02/19/19 08:09 PM
Posts: 1,534 Florida
CHRGR69
89 Dakota 2WD 3.9. Replaced the rack and PS pump. Now my tires are wearing on the inside edge. To much or to little toe?
Grandma always said I had "hands of gold"!
Re: Toe Issue
[Re: buildanother]
#2623445
02/19/19 08:50 PM
02/19/19 08:50 PM
CHRGR69
Is there a trick to determine how many turns on the tie rod ends to get it close?
Re: Toe Issue
[Re: CHRGR69]
#2623506
02/19/19 11:36 PM
02/19/19 11:36 PM
Posts: 10,586 Freeport IL USA
poorboy
Freeport IL USA
Is there a trick to determine how many turns on the tie rod ends to get it close? Yes, count the number of turns it takes to remove the old tie rod end, and install the new tie rod end the same number of turns. Probably too late for that though. Now you are forced to measure the toe you have and adjust accordingly. Back in the old dirt track days, we would measure the distance between a tire treads on the front of the tires and then measure the distance at the back of the tires using the same tire treads. Measuring at the back of the tires is often a challenge, there is a lot of stuff that gets in the way. Make your measurement as high on the tire as you can get a straight line, both in front of the tire and behind them. I prefer to go for the same measurement because this will only get you close. The only way to get it right is to have the vehicle aligned. Were I guessing, I would guess that if your wearing off the inside edge of the front tires, its likely toed out. If the tie rod ends are in front of the ball joints, drop the end on one side, and turn it in one turn. If the tie rod ends are behind the ball joints, drop the end on one side and turn the end out one turn. Then get it in for an alignment. Gene
Re: Toe Issue
[Re: poorboy]
#2623513
02/19/19 11:51 PM
02/19/19 11:51 PM
CHRGR69
I did count the turns of the ends, but I'm now thinking the new ends are longer then the old ones. Do I have to drop the ends to adjust, or just loosen the lock nut and spin the inner rod? I'll try the measuring of rear then front. Makes sense.
Re: Toe Issue
[Re: Cab_Burge]
#2623525
02/20/19 12:16 AM
02/20/19 12:16 AM
CHRGR69
Sorry, but I lost you at "and measure out the front side around 15 inches from the spindle center and then about the same amount out the other way and see how much difference there is"
Re: Toe Issue
[Re: CHRGR69]
#2623534
02/20/19 12:34 AM
02/20/19 12:34 AM
Posts: 2,046 ky.
kenworth_goose
ky.
89 Dakota 2WD 3.9. Replaced the rack and PS pump. Now my tires are wearing on the inside edge. To much or to little toe? Take it to get a proper alignment at a shop!
Re: Toe Issue
[Re: kenworth_goose]
#2623543
02/20/19 12:58 AM
02/20/19 12:58 AM
CHRGR69
Plan to when I eventually change the tires.
Re: Toe Issue
[Re: CHRGR69]
#2623990
02/20/19 11:50 PM
02/20/19 11:50 PM
poorboy
Freeport IL USA
Sorry, but I lost you at "and measure out the front side around 15 inches from the spindle center and then about the same amount out the other way and see how much difference there is" The 15" measurement "out the front of the spindle and the same amount out the other way" would be about the same as measuring at the front of the tire and measuring at the rear of the tire. He is just taking any variable the tires may cause out of the picture. Definitely more accurate, but also more difficult because you need to jack it up, remove the tires and set it on jackstands under the control arms so the weight is on the suspension, then use a straight edge placed against the rotors to measure across. Gene
Re: Toe Issue
[Re: CHRGR69]
#2624030
02/21/19 12:40 AM
02/21/19 12:40 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
You measure out to the end of each carpenter square to see how much toe in or toe out you have on the front side of the tires and again on the back side so you can see exactly you have If you have 55.6 on the front side and 55.5 inches on the back side you have a little less than 1/8 inch toe out I like to see between 1/32 to 3/32 of a inch toe in on my drag race cars with the front end raised up around a inch like it will be at WOT on the top end, but no toe out I was taught to not measure between the tires for toe in or toe out due to the tires having bulges on them
Re: Toe Issue
[Re: CHRGR69]
#2626237
02/26/19 11:07 AM
02/26/19 11:07 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
There's no trick. You eather set it right or you don't. That's the trick
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
Re: Toe Issue
[Re: Cab_Burge]
#2626726
02/27/19 02:06 PM
02/27/19 02:06 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I was taught to not measure between the tires for toe in or toe out due to the tires having bulges on them Makes sense. I never thought of that, but have always used the outer most tread to measure. Hook the tape into the tread and measure to the same point on opposite side. Was always good enough for the junk I drive. I get the ole gals stuff done at the local tire dealership, when we have new tires installed.
I have mechanical Aptitude. I can screw up anything.
