71 Cuda headlight buckets #2622378
02/17/19 12:07 AM
02/17/19 12:07 AM
S.E. Missouri
AeroMonte Offline OP
S.E. Missouri
I need a complete set of headlight buckets and rings for a 71 Barracuda. Does anybody reproduce these? Are they the same as a B body?
Re: 71 Cuda headlight buckets [Re: AeroMonte] #2622382
02/17/19 12:21 AM
02/17/19 12:21 AM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I have some with rings. Can post some pics tomorrow to make sure they are what you need... I know the stainless rings are correct just need to make sure on the buckets..
Re: 71 Cuda headlight buckets [Re: AeroMonte] #2622392
02/17/19 12:50 AM
02/17/19 12:50 AM
S.E. Missouri
S.E. Missouri
Ok thanks. I have no idea what is correct though. Mine are missing.
Re: 71 Cuda headlight buckets [Re: AeroMonte] #2622426
02/17/19 02:15 AM
02/17/19 02:15 AM
Maryland
MoparMike1974 Offline
Maryland
I think these can come from any early car with the smaller 4 headlights. B & C bodys would be a good source.
Re: 71 Cuda headlight buckets [Re: MoparMike1974] #2622706
02/17/19 09:57 PM
02/17/19 09:57 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Not really true. 1970 and older are different part Numbers and 71 Plymouth E-body is different assembly than 71 Plymouth B-body (different rings). I did not check and see if 72 were still the same. I have 3 of the correct 4 so far. I will check another spot on Monday and get back to you...
Re: 71 Cuda headlight buckets [Re: QuickBpBp] #2622773
02/18/19 12:42 AM
02/18/19 12:42 AM
S.E. Missouri
S.E. Missouri
Thank you.
Re: 71 Cuda headlight buckets [Re: AeroMonte] #2623041
02/18/19 08:02 PM
02/18/19 08:02 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Found the last one. PM sent.
