S60 axle removal #2622628
02/17/19 06:35 PM
02/17/19 06:35 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Need to remove axle in S60 with upgraded Helical Posi. Is there a C clip or does the axle pull out after removing retainer?
Re: S60 axle removal [Re: frank] #2622630
02/17/19 06:42 PM
02/17/19 06:42 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
No clip. remove flange bolts & pull out.
Re: S60 axle removal [Re: frank] #2622633
02/17/19 06:46 PM
02/17/19 06:46 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Same as an 8 3/4 that way.
Re: S60 axle removal [Re: frank] #2622663
02/17/19 07:56 PM
02/17/19 07:56 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
