Need more rear spring
#2621731
02/15/19 04:37 PM
02/15/19 04:37 PM
Posts: 4,179 California
mickm
California
I put the mopar street Hemi replacement springs on my car about 10 years ago when I did it up. The rear sat a good inch higher than stock, which was perfect for my setup; fit the tires nicely, and gave the car the rake I wanted.
After 5 years or so they did sag, and with a lot of complaints about those springs, I did some research here on the site, and chose one company to buy new springs from, who shall remain nameless, (rhymes with Eaton).
I got the stock height, knowing that it may or may not give me what I want. I talked with them about it and they simply said if that doesn't do it you will need to have there re-arched.
Once I put them on, it sat lower than what I wanted, to I had them re-arched at a very reputable, long standing truck center.
That was a little over 2 years ago, and they have sagged down that inch. Unfortunately, that doesn't work for my tire clearance, so I need that extra inch.
I really didn't expect these springs to sag after 2 years, manufacturer said "sorry".
The truck guy said re-arching them is not the best idea, probably won't stick, add a leaf.
So, where do I get single leafs from? I've never done it, but it doesn't sound like it's a big deal to disassemble the springs and add one more leaf.
Also, if I only want an extra inch, how do I know what size leaf to add?
Re: Need more rear spring
[Re: mickm]
#2621779
02/15/19 06:13 PM
02/15/19 06:13 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
When dad and I were getting his 73 Challenger back on the road in the 90's, we had a shop add an extra leaf. They added a "used" main leaf that had the eyelets cut off. The extra leaf was installed directly under the original main leaf and extended from eyelet to eyelet. Also, if I only want an extra inch, how do I know what size leaf to add? Probably trial and error.
[Re: krautrock]
#2621786
02/15/19 06:30 PM
02/15/19 06:30 PM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
why not have that spring shop that re-arched them add a leaf to the pack? This /\ I had a set done for my Duster and they added a leaf to each side.
[Re: mickm]
#2621800
02/15/19 07:18 PM
02/15/19 07:18 PM
Posts: 2,843 Connecticut
FurryStump
Connecticut
So, you may find it very difficult to get an accurate 1” by adding leaves. On a bodies you can flip the front spring mount which would give you about an inch, not sure on b body. I have seen people put an extra long spring on and cut it down a little at a time in the back section to adjust the rear spring rate. Cut it with cut off wheel. Also you could buy an adjustable front spring mount and set it for the right hieght with your settled springs
[Re: FurryStump]
#2621882
02/15/19 10:28 PM
02/15/19 10:28 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
So, you may find it very difficult to get an accurate 1” by adding leaves. On a bodies you can flip the front spring mount which would give you about an inch, not sure on b body. I have seen people put an extra long spring on and cut it down a little at a time in the back section to adjust the rear spring rate. Cut it with cut off wheel. Also you could buy an adjustable front spring mount and set it for the right hieght with your settled springs Flipping the front hangar LOWERS the car.
[Re: burdar]
#2621883
02/15/19 10:30 PM
02/15/19 10:30 PM
forphorty
oklahoma
When dad and I were getting his 73 Challenger back on the road in the 90's, we had a shop add an extra leaf. They added a "used" main leaf that had the eyelets cut off. The extra leaf was installed directly under the original main leaf and extended from eyelet to eyelet. Also, if I only want an extra inch, how do I know what size leaf to add? Probably trial and error. I have also done the "main leaf with the eyes cut off" thing. Works great.
[Re: mickm]
#2621884
02/15/19 10:30 PM
02/15/19 10:30 PM
Posts: 12,284 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yep. Been there, done that. After fighting this issue for years on different cars, I finally bought some Hellwig helper leaf springs. I mounted them on top of the rear segment instead of under as they were supposed to be mounted. That way they are completely out of sight. And I can adjust them to get the height that I want. If anything ever sags, in just a few minutes, I have the car right back where I want it. No guess work, saves a lot of time, money, and aggravation. And nobody knows they are there.
Master, again and still
[Re: mickm]
#2621910
02/15/19 11:22 PM
02/15/19 11:22 PM
Posts: 22,728 Bitopia
jcc
Bitopia
Nothing to add, but you are the world travel writer, correct? Anything forthcoming?
[Re: mickm]
#2621911
02/15/19 11:22 PM
02/15/19 11:22 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I know I am gonna catch Heck for suggesting this BUT, I would put Monroe air shocks on it, 30,40 psi will raise it about an inch & that little bit of pressure will NOT hurt the ride or the upper shock x member.
[Re: krautrock]
#2622015
02/16/19 04:23 AM
02/16/19 04:23 AM
mickm
California
why not have that spring shop that re-arched them add a leaf to the pack? He was pretty dubious about it, basically said bent metal is bent metal. If they sagged once when arched, he would expect it to do it again. I still may gamble and give it a shot, but I'm tempted to take his word for it.
[Re: mickm]
#2622122
02/16/19 02:06 PM
02/16/19 02:06 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Mick, We did the add a leaf to the Outlaw DennisH's car, and it worked great and has been consistent ride-heigth wise.
It was from summit and originally intended for a 4wd truck. As I recall, it was about 18" long.
Either that, or I have several sets of passenger side SS springs you can try, which is what I run on both my cars. They both weigh 3700 lbs, but I found that the 3200 lbs passenger side springs work best for my needs. I did have to add a modified set of slapper bars to both cars, as the power was wrapping the front segments. They now ride and hook better than anything else I've tried.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: CSK]
#2622335
02/16/19 10:26 PM
02/16/19 10:26 PM
Posts: 737 Michigan
BlueRacer69
I know I am gonna catch Heck for suggesting this BUT, I would put Monroe air shocks on it, 30,40 psi will raise it about an inch & that little bit of pressure will NOT hurt the ride or the upper shock x member. Agree with what csk said. For around $100 bucks Monroe Air Shocks will fix your problem. I ran them for a number of years on the back of my 69 Dart without any issues as did most guys back in those days. Raised my rear end up and gave my car a nice rake in the rear. Trick is not to blow them up to 100 lbs and use them like that all the time. I use to fill mine to about 60 or 70 lbs. Or order a new set of spring from ESPO Springs and Things with a +2 inch lift.
[Re: DaveRS23]
#2622689
02/17/19 08:55 PM
02/17/19 08:55 PM
Torq37
Do you remember which Hellwig's you used? EZ-550 maybe? How is it that they are adjustable, from the literature it looks like they just clamp on top the spring.
[Re: Torq37]
#2622738
02/17/19 11:28 PM
02/17/19 11:28 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'll have to look for the Hellwig number, it's been a few years, but I have it.
Yes, they are supposed to be mounted underneath the spring. But with only a little mod or two, they will go over the rear segment. And they are strong enough that the rear clamp does not need to pull the helper leaf down against the leaf spring.
It will be an inch or so above the leaf allowing height adjustment.
I have successfully used this on several cars after trying re-arching and buying new springs. The helper leafs are the only thing I have tried that allows me to have complete control over the height and right to left level and weight distribution.
The Cuda can pull a 1.5 60ft, so I haven't found a down side to the helper springs yet.
I will follow up with the Hellwig number and try to post a shot of them on the Cuda. Probably tomorrow.
