74 360 compression boost
#2621719
02/15/19 04:11 PM
02/15/19 04:11 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
I have a 74 Dodge Ramcharger I am turning into a daily driver. I am going to rebuild the original 5.9 2bbl with mild performance upgrades. What is the best way to boost compression on this motor without spending a ton of cash? The idea of using a set of 73 340 pistons maybe possible if the compression height isn't too tall. Maybe use a thicker gasket if it is at or over zero deck.
Question 1, does anyone know the compression height of the 73 340 piston?
Does anyone make a budget rebuilt kit with higher than stock compression? Something like this?
https://www.ebay.com/itm/DODGE-CHRYSLER-MOPAR-360-5-9L-OHV-V8-1971-1979-ENGINE-REBUILD-OVERHAUL-KIT/302755246642?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160727114228%26meid%3D04ce5944beeb4b6584bf33bbe6354a67%26pid%3D100290%26rk%3D3%26rkt%3D4%26sd%3D382757374416%26itm%3D302755246642&_trksid=p2060778.c100290.m3507
Thank you
Re: 74 360 compression boost
[Re: B1MAXX]
#2622105
02/16/19 01:27 PM
02/16/19 01:27 PM
RapidRobert
What Jerry said, some mag heads/thin gaskets (need flat decks) would be the easiest (decide how to deal with the intake bolt angle change/several options). If it needs to come out I would consider strokeing it. 4" cast cranks are cheap now & the KB stroker pistons ain't too bad, then just need to balance it. You need TORQUE cuz ramchargers are heavy heavy (I had one). 40 over on the block would let you use std 340 pistons if the CH can be handled & cometic has custom thicker gaskets but are $$$. As you know you want the SCR to match your fuel & adding some race gas to a DD is a pain for some people (how hardcore are you!) I think the highest C.H. 360 piston is the KB H405cp at 1.637. do see how far you are in the hole when the heads come off.
[Re: urdustd]
#2623200
02/19/19 02:51 AM
02/19/19 02:51 AM
RapidRobert
Oh OK so there are pistons with more CH than the 1.637's
