Re: Rotten roofs
[Re: modelmakerinc]
#2617748
02/06/19 12:33 PM
02/06/19 12:33 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Do I ever wish SOMEONE would reproduce those panels! Even if they were partial patch panels it would make life easier. I used a donor roof and cut out what I needed but even it wasn't perfect and man what a PITA it is.
Technically I don't think it's a design flaw as you find that once you get in there you see it's just bare metal, no treatment or paint to speak of.
But while we are at it can We wish for 87-93 wing window seals too?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Rotten roofs
[Re: Guitar Jones]
#2617761
02/06/19 12:50 PM
02/06/19 12:50 PM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
But while we are at it can We wish for 87-93 wing window seals too? I have used the 78-86 wing window seals on 87-93 trucks with no issues.
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
Re: Rotten roofs
[Re: ViperDave]
#2617804
02/06/19 01:51 PM
02/06/19 01:51 PM
Guitar Jones
But while we are at it can We wish for 87-93 wing window seals too? I have used the 78-86 wing window seals on 87-93 trucks with no issues. I've heard others say this too but the upper pivot is different and the older wing windows have a metal base on them that the newer ones do not. I don't see how that is going to seal very well and I don't want to waste the money on trying unless I'm sure. Maybe you could post some pics of how well they fit?
Re: Rotten roofs
[Re: modelmakerinc]
#2617934
02/06/19 06:10 PM
02/06/19 06:10 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
FWIW, it wasn't limited to the full size trucks... Had to do my 93 Dakota as the windshield area was shot.
Common sense is a flower that does not grow in everybody's garden
Re: Rotten roofs
[Re: Guitar Jones]
#2617957
02/06/19 07:07 PM
02/06/19 07:07 PM
Posts: 15,487 Florida
scratchnfotraction
But while we are at it can We wish for 87-93 wing window seals too? I have used the 78-86 wing window seals on 87-93 trucks with no issues. I've heard others say this too but the upper pivot is different and the older wing windows have a metal base on them that the newer ones do not. I don't see how that is going to seal very well and I don't want to waste the money on trying unless I'm sure. Maybe you could post some pics of how well they fit? some glass has 3 holes and some have 2 holes had that mix match on my 85 for a long time till I got a good set of 2 hole wings that matched with good frames. I always thought 3 hole was the early ones but me thinks they are the later ones with no new rubbers?
Re: Rotten roofs
[Re: modelmakerinc]
#2617983
02/06/19 08:25 PM
02/06/19 08:25 PM
Guitar Jones
Yep my 92 and 93 have 3 holes and no metal on the bottom edge.
That metal base has to add at least an 1/8" of thickness to the glass. I can't see how that would possibly seal.
Re: Rotten roofs
[Re: Guitar Jones]
#2618166
02/07/19 10:13 AM
02/07/19 10:13 AM
ViperDave
enfield, CT
heres the seals I did on a 91
Re: Rotten roofs
[Re: modelmakerinc]
#2618182
02/07/19 11:02 AM
02/07/19 11:02 AM
Guitar Jones
Thanks for the pics. Do they really not leak water or wind? Others have said they are still adding coins to the latch handle to tighten them up.
Re: Rotten roofs
[Re: modelmakerinc]
#2618247
02/07/19 01:51 PM
02/07/19 01:51 PM
ViperDave
enfield, CT
they leak a little wind, but I cant hear it or feel it over the cummins.
No rain although my trucks don't sit outside often. new seals don't really combat the coin fix if the latch is worn.
Re: Rotten roofs
[Re: bbtrux]
#2618388
02/07/19 06:26 PM
02/07/19 06:26 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Too bad about that 80's roof. I get your disappointment. Re; Rotten roofs I live the salt = rust part of the country. I have a '76 N a '78. One has surface rust the other is still solid. My ? I used a solid 80's cab from some one here. Now you can go back to the wing window thing.
I have mechanical Aptitude. I can screw up anything.
Re: Rotten roofs
[Re: modelmakerinc]
#2618815
02/08/19 07:25 PM
02/08/19 07:25 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Scratchin' you the man with your trucks, and building. I envy your talent.
The vent windows on my '79 whistle like crazy. My solution is open them, lol. I don't have a/c anyhow, and we don't get much cold weather here. I sure would like to have them quiet though. The main problem with mine seems to be the loose handles more than the rubber. I'm luckY to have a solid truck. I just received new windshield from lmctruck last night. Mine is foggy around edges especially from de-lamination. Maybe when I have old one out I'll have more access to spray underside of roof for protection? Don't the roofs usually rust inside out?
I don't understand why lmctruck doesn't make replacement roofs for the 72-80 at least!!! Maybe it's too expensive to produce? But even front panels seem like they would be extremely profitable!
LET'S ALL START EMAILING LMC WITH REQUESTS TO START MAKING REPLACEMENT ROOFS!!
Facts are stubborn things.
Re: Rotten roofs
[Re: modelmakerinc]
#2618833
02/08/19 08:54 PM
02/08/19 08:54 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just sent this email to LMC:
LMC truck needs to make replacement roofs, or at least replacement roof panels for the 1972-1980 (or thru 1993 would be better!) Dodge light duty pickups!!!
There's a huge demand. This was a rust prone area, and there are so many trucks out there waiting to be saved, and no donors!!!
Please, please, please!
Here's the email address: CustomerCare@longmotor.net
Re: Rotten roofs
[Re: modelmakerinc]
#2619018
02/09/19 12:50 PM
02/09/19 12:50 PM
Posts: 206 Paducah, KY USA Earth
jcruse64
Exline, while focusing on the Swepties series, has begun producing 72-80 sheet metal, including a bigger floor pan replacement. This last week, on one of the Mopar truck FB pages, someone started a post on a wish-list for body stuff. Kenny, the owner of Exline, posted that he will be coming out with more 72-80 stuff this year, and asked for more suggestions. I told him that complete roof sections seem to be a HUGE request across many FB groups and forums like this one. Maybe he'll try it.
Re: Rotten roofs
[Re: Rhinodart]
#2619219
02/09/19 10:55 PM
02/09/19 10:55 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
How about club cab roofs? I don't see much call for one of those, did they rust the same? I have had a nice roof sale for a few years with no interest. Maybe coming in the "spring of 2019"?
Re: Rotten roofs
[Re: bbtrux]
#2619302
02/10/19 10:35 AM
02/10/19 10:35 AM
Posts: 5,954 Greenville, PA
redraptor
Greenville, PA
I saved a clean 84 roof , and held onto it for a year. Noone would buy or trade for it, then couldnt give it away. Had to scrap it. made me sick. I had a core support, same outcome. Florida and other coastline areas eat up roofs of everything. Personally, I don't think there are many people who would take on a proper roof repair, but having a patch panel would help.
Re: Rotten roofs
[Re: redraptor]
#2619320
02/10/19 11:45 AM
02/10/19 11:45 AM
Guitar Jones
I saved a clean 84 roof , and held onto it for a year. Noone would buy or trade for it, then couldnt give it away. Had to scrap it. made me sick. I had a core support, same outcome. Florida and other coastline areas eat up roofs of everything. Personally, I don't think there are many people who would take on a proper roof repair, but having a patch panel would help. Well really you need 4 pieces. The outer and inner panels, the header panel sandwiched between the two and the drip rail.
Re: Rotten roofs
[Re: Guitar Jones]
#2619321
02/10/19 11:49 AM
02/10/19 11:49 AM
redraptor
Greenville, PA
Exactly
Re: Rotten roofs
[Re: redraptor]
#2619369
02/10/19 02:37 PM
02/10/19 02:37 PM
Guitar Jones
Exactly But really even if you had just a new header panel it would make the job easier with a donor roof. When I did mine by the time I drilled out all the spot welds from the donor what I had left was basically four slices of swiss cheese.
Re: Rotten roofs
[Re: modelmakerinc]
#2619392
02/10/19 03:11 PM
02/10/19 03:11 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
I've got some dealer stuff Dad brought home from the local Dodge dealer in the early '70s. I remember one of the pics showing a bare cab on the assembly line, praising the rust preventive measures being taken.
1981 Dodge D150 360 auto
Re: Rotten roofs
[Re: basketcase]
#2619503
02/10/19 06:58 PM
02/10/19 06:58 PM
Guitar Jones
I've got some dealer stuff Dad brought home from the local Dodge dealer in the early '70s. I remember one of the pics showing a bare cab on the assembly line, praising the rust preventive measures being taken. I think the early trucks were better treated. By the late 80's early 90's they didn't do much.
Re: Rotten roofs
[Re: modelmakerinc]
#2619559
02/10/19 10:26 PM
02/10/19 10:26 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
You guys that had donor roofs and rad supports that were stuck with them; you weren't willing to box and ship I'm sure, and I don't blame you. A company the does this will undoubtedly have better success, AND can do it a lower costs.
Re: Rotten roofs
[Re: BulletBob]
#2619566
02/10/19 10:48 PM
02/10/19 10:48 PM
Guitar Jones
I know Kenny he is a straight up guy, he has acquired the dies to punch many sheetmetal parts for our trucks 49-93 Well I hope he can start doing roof pieces because without that all the doors, fenders, cab corners and such in the world will be useless without them.
Re: Rotten roofs
[Re: Guitar Jones]
#2620122
02/12/19 01:55 AM
02/12/19 01:55 AM
Posts: 257 Alberta
440_Offroader
Alberta
"I think the early trucks were better treated. By the late 80's early 90's they didn't do much."
Never thought of that... All my 70's trucks I've owned never had rusty roofs. My 92' sure did have the rusty roof syndrome.
Re: Rotten roofs
[Re: scratchnfotraction]
#2620203
02/12/19 11:03 AM
02/12/19 11:03 AM
scratchnfotraction
done welding/grinding add some all metal and sand it off smooth and shoot it with 6 gallons of bed liner.
Re: Rotten roofs
[Re: modelmakerinc]
#2620215
02/12/19 12:01 PM
02/12/19 12:01 PM
Guitar Jones
The problem with that repair is it didn't address the root cause. It may be ok and last long enough for what ever your plans are but if you had opened up that roof you would have been greeted with bare metal and a lot more rust.
I have some pics on my phone I'll see what I can do to post them.
Re: Rotten roofs
[Re: modelmakerinc]
#2620218
02/12/19 12:09 PM
02/12/19 12:09 PM
Guitar Jones
Re: Rotten roofs
[Re: modelmakerinc]
#2620220
02/12/19 12:12 PM
02/12/19 12:12 PM
Guitar Jones
I sprayed Eastwood's inside frame coating inside the roof and all the panels. There wasn't a whole lot of welding most of it was done using panel bond. That was on the advice of my body and paint guy brother in law.
The way it's put together is you have the inner roof panel. The header panel is attached to it. Then the drip rail is attached to the header panel and the outer roof panel is attached to the drip rail.
Re: Rotten roofs
[Re: modelmakerinc]
#2620221
02/12/19 12:21 PM
02/12/19 12:21 PM
Guitar Jones
Re: Rotten roofs
#2620286
02/12/19 03:24 PM
02/12/19 03:24 PM
Guitar Jones
yikes! right click save those pics for reference. thanks for sharing those.
yes, I just cut a piece out of my 88 truck last weekend and found hand fulls of rust scale just laying there.
getting after it early is the key to keeping the work down. unfortunately they are always left as is for way to long then giving up on.
looks like we can start a faze in another 30 yrs with convertible/open top trucks. LOL! When we were fixing it I commented to by buddy, "It doesn't have to last 30 years, I'll be dead by then." That would put me at 92
Re: Rotten roofs
[Re: rich006]
#2620349
02/12/19 05:39 PM
02/12/19 05:39 PM
Guitar Jones
Great pics, thanks. Does anyone have experience with a cab that has had a sun visor on it? I've got another candidate truck that looks pretty good but it has a visor. Without taking it apart I won't know the condition of the roof. The donor truck I used had a visor on it. The rest of the truck was rotten but the roof was pretty nice. They did seal the holes they drilled though. I guess it all depends.
Re: Rotten roofs
[Re: jerseybud]
#2620350
02/12/19 05:42 PM
02/12/19 05:42 PM
Guitar Jones
I studied your thread before we dove into my roof. You are right about it not being any fun. I swear, between the two roofs I must have drilled out 100 haphazardly placed spot welds.
Re: Rotten roofs
[Re: basketcase]
#2620969
02/13/19 09:33 PM
02/13/19 09:33 PM
Guitar Jones
Scratch is always building something! Like to see pics of this build! Yep, I used to have that kind of drive and ambition. Now I'm just old and tired.
Re: Rotten roofs
[Re: basketcase]
#2621180
02/14/19 10:53 AM
02/14/19 10:53 AM
scratchnfotraction
Scratch is always building something! Like to see pics of this build! I will start a pic page of all my junk in progress
Re: Rotten roofs
#2621826
02/15/19 08:24 PM
02/15/19 08:24 PM
redraptor
Greenville, PA
Scratch is always building something! Like to see pics of this build! I will start a pic page of all my junk in progress Ooooo! Truck Pourn!!!
Re: Rotten roofs
#2622273
02/16/19 07:46 PM
02/16/19 07:46 PM
bboogieart
Lost and Spaced
looks like we can start a faze in another 30 yrs with convertible/open top trucks. LOL! Funny you mention that. I was thinking of a summer time open top for one of my rust buckets, as well as a 4 door Fury. I figured it'd be a great way of getting some use out of a rusty junker. Any one remember the 80's, or maybe 90's (?) convertible Dakotas?
Re: Rotten roofs
[Re: bboogieart]
#2653055
05/07/19 04:25 PM
05/07/19 04:25 PM
Posts: 9,887 USA
CrAlt
USA
I see I am not the only one with this problem....
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: Rotten roofs
[Re: modelmakerinc]
#2653296
05/08/19 09:04 AM
05/08/19 09:04 AM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Guys, I am looking for a 4x4 short bed truck but so many of them have the rotten roof, I know it's some design flaw and there are very few that do not show the hidden damage.
Is any of the body panel companies reproducing the roof panels? I have looked a little but have yet to find them.
Do you think it would be a viable product for AMD to produce? Or am I having one cut off of an Arizona doner? Same issues here. Fortunately there’s some options for me. Depending how far back the rot goes and it’s not into the inner frame you can get good clean patch panels here in Arizona. I have a club cab roof I can’t bring myself to cut.
Abe Lincoln
Re: Rotten roofs
[Re: volaredon]
#2654115
05/10/19 06:44 PM
05/10/19 06:44 PM
basketcase
east side of Ohio
I would think the fitment would be the same, but the later trucks had a bodyline, where the older ones were more rounded.
Re: Rotten roofs
[Re: basketcase]
#2654581
05/12/19 12:33 PM
05/12/19 12:33 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
My '79 W150 is from out west and APPEARS rust free, but from this thread, I'm concerned about what lurks beneath.
I wonder if I would put some rust converter in my pump sprayer (I realize it may ruin my sprayer), and after removing the visor mounts, spray the best I can all up in the inner roof panel to kill any rust that could be lurking under there? Maybe I can spray through the dome light too if I remove that.
Re: Rotten roofs
[Re: larrymopar360]
#2654596
05/12/19 12:55 PM
05/12/19 12:55 PM
dart4forte
Mesa, Arizona
Here’s another repair made I took off the net
Abe Lincoln
Re: Rotten roofs
[Re: Guitar Jones]
#2654885
05/13/19 09:05 AM
05/13/19 09:05 AM
Posts: 1,179 Canada
demon
Canada
But while we are at it can We wish for 87-93 wing window seals too? Auto Metal Direct has a poll on their Facebook page, asking what we would like to see reproduced. Everyone should go there, and ask for the parts these trucks need. Here's what I would like to see. Roof skins for 72-80 regular cabs. Roof skins for 81-93 Cabs Full one piece interior floors for 72-93 cabs. (There are several versions). Bed sides for 73-80. Short and long. Bed sides for 81-93 short and long. Go to the AMD Facebook page, vote and add a comment.
