69 Cuda red plastic wheel well liner restoration tips?
#2616658
02/03/19 11:38 PM
02/03/19 11:38 PM
Posts: 755 Oregon
moparmedic
I am building a '69 340 Barracuda that came with the red plastic wheel well liners. The rears are in great shape but are faded and the fronts both have a small area where the tires rubbed through. My main question is, does anyone have a recommendation for dying or painting them? I would like to bring the red back as they are kind of pale. As far as repairing the areas that were rubbed through I am assuming fiberglass would be the best choice. Any other plastic repair suggestions? Thanks!
1968 Coronet 1968 Charger 1966 A100 Pickup 1967 Barracuda 1970 Challenger 1972 Challenger 1973 Barracuda 2021 Ram 2500
Re: 69 Cuda red plastic wheel well liner restoration tips?
[Re: moparmedic]
#2616723
02/04/19 03:11 AM
02/04/19 03:11 AM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
I'm surprised these have not been reproduced by now. I've seen one set of originals on a B-fish in a wrecking yard in Phoenix back in the mid 80's. They were all broke to heck, & the material was a thin pliable plastic. You could get these on '67 GTO's as an option I believe (I know they were available on GTO's from the factory as an option - pretty sure it was for 1967). I doubt there is much chance a set of originals could have survived all these years unless they are on a real low-miler garage queen.
[Re: ScottSmith_Harms]
#2616795
02/04/19 12:19 PM
02/04/19 12:19 PM
Posts: 755 Oregon
moparmedic
Good info, thanks! I haven't done any plastic welding before and I will have to add a small amount of material to the rub through areas. I think they are worth saving if I can come up with the right process to do it. Fortunately the rears only need paint to look great.
