Re: Doug’s or TTI’s [Re: rscottick] #2610569
01/22/19 06:17 PM
01/22/19 06:17 PM
michigan
rscottick Offline OP
michigan
Well ordered the Dougs thru autozone to try
Re: Doug’s or TTI’s [Re: rscottick] #2610598
01/22/19 07:02 PM
01/22/19 07:02 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Beware the JetHot coating is a joke and can't stand roadsalt one bit.
The collector and lower ends of the tubes rust like crazy and looked liked they had been on the car for 6 years orso after driving just one winter with them.
Re: Doug’s or TTI’s [Re: BigBlockMopar] #2610638
01/22/19 08:28 PM
01/22/19 08:28 PM
Cab_Burge Online work
Cab_Burge  Online Work
Me thinks your country may allow a different strength road deicers than most of the states here do whiney
The dang invoirmental activist whiny snow flake babies complain about everything they can here runaway stirthepot devil
Re: Doug’s or TTI’s [Re: rscottick] #2610643
01/22/19 08:30 PM
01/22/19 08:30 PM
The Netherlands
The Netherlands
Quite possible perhaps.
The Gubment takes road de-icing quite seriously here.
...although, our roads seem sometimes more slippery because of all the salt then some ice patches wink
Re: Doug’s or TTI’s [Re: rscottick] #2610748
01/22/19 11:10 PM
01/22/19 11:10 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
I have run both dougs and tti. the tti are the best quality and fit hands down. imo tti's are the best off the shelf headers money can buy.
Re: Doug’s or TTI’s [Re: 9secondsatellite] #2610905
01/23/19 08:44 AM
01/23/19 08:44 AM
Washington state
pinkmeepmeep Offline
Washington state
I did the dougs autozone gig bare and had them sent out and coated for my 71 duster. They do not fit right. I tried everything and eventually heated up the right side tube and dimpled it. The idler arm was cutting into the header when I turned the wheel. Pro form idler arm. Everything else was new. Not sure what the deal was. I checked everything and rechecked, and checked again. never had that problem with the three other cars that had TTI's. I wasn't keen on the idea of a slip tube so I wanted to try dougs. Next time I will use tti's. just my 2bits
Re: Doug’s or TTI’s [Re: Cab_Burge] #2615177
01/31/19 04:57 PM
01/31/19 04:57 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
And guess what that strenght road salt does to the rest of our old cars stirthepot
Its terrible realy but also nice to have less ice on the roads,if more people where smart and drove on real studded wintertires the need for salt would be much smaller.
Re: Doug’s or TTI’s [Re: rscottick] #2615224
01/31/19 07:01 PM
01/31/19 07:01 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Magnesium Chloride. Will trash your paint if you don't rinse it off, but won't help the rust along. Have to lay it down before the freeze though.
Re: Doug’s or TTI’s [Re: rscottick] #2615232
01/31/19 07:18 PM
01/31/19 07:18 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
Doug’s are supposed to have a hair more ground clearance then the tti too. On the abody anyway.
I’d save the money and go Doug’s with the discount code that cracked posted.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
