What is correct routing of speedoable on 69 B - 4-spd #261447
03/22/09 03:05 AM
03/22/09 03:05 AM
God's Country - Etowah, TN.
A34 Offline OP
A34  Offline OP
Hey guys,
Fought with this some today. What is the correct routing for the speedocable on a 1969 440 B-body 4-spd car?
The last one melted sitting on the h-pipe where it turns and goes into the tranny.
Any tricks for getting the cable on the speedo? It didn't seem to want to lock in.
Thanks !
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: What is correct routing of speedoable on 69 B - 4-spd [Re: A34] #261448
03/22/09 08:58 AM
03/22/09 08:58 AM
theres a cable tab on the drivers side underneath floorboard which the cable goes in to keep it away from the head pipe, its a clean and straight run right to the speedo on the transmission.
Re: What is correct routing of speedoable on 69 B - 4-spd #261449
03/22/09 10:57 AM
03/22/09 10:57 AM
A34 Offline OP
A34  Offline OP
Thanks, I had a section of drivers front floorboard replaced . Guess they left that tab off.
DEO VINDICE
Re: What is correct routing of speedoable on 69 B - 4-spd [Re: A34] #261450
03/22/09 01:15 PM
03/22/09 01:15 PM
Same happened with my car too.
Re: What is correct routing of speedoable on 69 B - 4-spd [Re: ] #261451
03/22/09 02:52 PM
03/22/09 02:52 PM
A34 Offline OP
A34  Offline OP
I've come up with a temporary solution. I took a fuel line bracket I had sitting around and bolted it to the floorboard through the gas pedal stud.
I routed the cable through it, and it seems be working ok.
After a little bit of this , I did some of this , I hope I won't be doing any of this in the near future.
DEO VINDICE
