Towing a gooseneck race trailer
#2613124
01/27/19 06:17 PM
01/27/19 06:17 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Who on here tows a gooseneck race trailer with a pick up with a bed (not a flat bed)? How much clearance between the bed of the pick up bed and the bottom of the trailer do you run? I just acquired a 48' gooseneck w/ living quarters and am planning to pull it with a 2006 Dodge 3500 4 wheel drive, standard cab, 8' bed. With no load, the rear end of the truck sits at 59" high. The way the trailer is set up now, there is approx. 8" between the bed and the trailer. Is this enough, or are adjustments needed?
Thanks, Brian
Re: Towing a gooseneck race trailer
[Re: '72CudaRacer]
#2613179
01/27/19 08:30 PM
01/27/19 08:30 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I do... If you got that much you are fine, cant take a pic up close but I have less and don't have any issues.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: '72CudaRacer]
#2613443
01/28/19 12:03 PM
01/28/19 12:03 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I have about the same. I'm careful about getting my truck too much off level with the trailer when turning out. I also have mine converted to a fifth wheel hitch.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: '72CudaRacer]
#2613518
01/28/19 02:43 PM
01/28/19 02:43 PM
Triple Threat
Renton Washington
8" sounds about right. There's times the bed will get close, but no issues so far.
[Re: Triple Threat]
#2614395
01/30/19 01:10 AM
01/30/19 01:10 AM
'72CudaRacer
Mooresburg, Tn
Thanks for the confidence guys, fingers crossed! Funny thing is, I've worked on tractor/trailers for over 40 year and I don't think anything at all about wheeling a tandom axle, double-wide bunk conventional Freightliner & a 53' trailer down the highway for a road test. My previous race trailer is a 32' tag, only 6' shorter total length than this new GN. It just looks tight to me. All in what you get used to, I guess. Thanks, Brian
[Re: '72CudaRacer]
#2614417
01/30/19 02:02 AM
01/30/19 02:02 AM
Posts: 43,233 Bend,OR USA
Cab_Burge
A goose neck or 5th wheel trailer will tow a bunch better than any tag My 2006 Ram 3500 4x4 single wheel four door towed my 34 ft. 5th wheel way better than my 24 ft. Pace Shadow Let us your results after pulling the first time I do have a friend who had several enclosed 24 ft. tag race trailers before buying a new goose neck 48 Ft. really nice race trailer, he had all the commercial endorsement for the really big trucks for his work. He pick the new trailer up in Denver,CO with his 1995 Ram 3500 5 speed dually extended cab, he hated that trailer in less than five miles according to him when he got home to SO CA
