Looking for AAR Cuda 305124 I have your motor
#2613671
01/28/19 08:30 PM
01/28/19 08:30 PM
Posts: 33 Ontario, Canada
Todd Lepine
Ontario, Canada
Hello, I have recently purchased a 1970 Challenger T/A with out the original motor. I have the T/A block for 305124 if you have that car I have your motor. I am looking for my original T/A block Vin# 311287 Thanks, Todd
Todd Lepine, (705)977-1502
Looking for AAR BS23J0B305124 I have your motor
[Re: Todd Lepine]
#2615349
01/31/19 11:52 PM
01/31/19 11:52 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Todd, you should also post in the 'stickied' thread up top, for the AAR block you have & a separate thread for the block you are hoping to find. (non-sticked threads can drop off over time) More about a possible block for 311287 below that Todd is already aware of, maybe it will ring a bell or two? A TA block was listed on Syracuse, NY Craigslist in February 2014. The VIN listed in the text was 211287 which is too low for any AAR or T/A. Typo in the ad? Number hard to read? I asked about it back then but no response from the seller. The seller was contacted by Todd recently & he was told that an AAR owner in Michigan bought it. Did I get that right Todd? MI AAR owners, does that ring any bells?
Re: Looking for AAR Cuda 305124 I have your motor
[Re: Todd Lepine]
#2615352
01/31/19 11:53 PM
01/31/19 11:53 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
1970 mopar 340 TA block - $4500 (Hamburg) I am selling a 1970 dodge 340 TA engine block with a steel crankshaft and caps, This is a very rare engine that only came in the 1970 Cuda AAR or 1970 Challenger TA with a 340 six pack. The casting # is 3577130TA340.8 with production date 11/69. The vin # is OB211287. If interested call 716-xxx-xxxx. Please dont call for any other reason.
Location: Hamburg do NOT contact me with unsolicited services or offers Text copied & pasted above from the ad I just mentioned with the sellers phone number removed. (Todd has the whole number already)
Re: Looking for AAR BS23J0B305124 I have your motor
[Re: 6bblgt]
#2615358
02/01/19 12:02 AM
02/01/19 12:02 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Blocks & transmissions were stamped with a space after the B, so to cover more of the bases; He has block 0B 305124 & is hoping to find 0B 311287
[Re: Alaskan_TA]
#2615553
02/01/19 12:55 PM
02/01/19 12:55 PM
Todd Lepine
Ontario, Canada
Yes Sir, I did in fact call the number to which Barry gave me of the original posting. The gentlemen told me that he couldn't remember the details of either the Block vin sequence nor could he give me a contact number for the person he sold the block to. He could only say that it was someone out of Michigan State.. I'd like to give him another call and see if he would agree to post his contact information on one of these sites. Maybe "fingers crossed" the owner of the block in Michigan might see his thread. Thanks, Toad
[Re: Alaskan_TA]
#2615555
02/01/19 12:59 PM
02/01/19 12:59 PM
Todd Lepine
Ontario, Canada
Here's a question; Can a T/A block casting date be accurate to determine the vin Sequence time? Or were they all Cast within a very short run. Toad
[Re: Alaskan_TA]
#2615609
02/01/19 03:20 PM
02/01/19 03:20 PM
Todd Lepine
Ontario, Canada
That's right, How ever I have read that almost all of the T/A's were made before Friday April 17th of 1970.. So the assembly of most T/a's took place in a couple of weeks?
[Re: Todd Lepine]
#2615674
02/01/19 06:29 PM
02/01/19 06:29 PM
Todd Lepine
Ontario, Canada
Point being that The Fender tag build date of the Car won't line up with the build date of the motor.. right? Motor assembly will always be before the fender tag of the car, but by how much? Thanks
[Re: 6bblgt]
#2615793
02/02/19 12:20 AM
02/02/19 12:20 AM
Todd Lepine
Ontario, Canada
No Broadcast sheet yet, but I have just purchased the car recently and haven't had a chance to go through it thoroughly. I hope that its in the car somewhere..
[Re: Todd Lepine]
#2616288
02/03/19 02:33 AM
02/03/19 02:33 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Point being that The Fender tag build date of the Car won't line up with the build date of the motor.. right? Motor assembly will always be before the fender tag of the car, but by how much? Thanks Hey Todd, Back on topic here. The fender tag / broadcast sheet date is the SPD (Scheduled Production Date) which is the date they HOPED to build the car when the order was first entered into the system. But actual build dates were not recorded except in unusual circumstances, like 'last' one on any given calendar day. The actual build month was shown on the Mylar door stickers. But some cars were actually built earlier or later than their SPD & original door stickers can be earlier or later by a month or more also. One example is my T/A, 417 SPD , April Mylar, but the numbers matching engine was assembled April 22, so from that I know that the car was finished in April, but with a final assemble date on the engine of 422, I know that the car was finished in April, but later than the hoped for date of 417. These cars were not built in actual VIN order either. So the only way to know the final assembly date on any numbers matching engine (or transmission) is to look at the original block / transmission as the case may be that matches the VIN of the car - if all stampings are in fact original to them.
