Sputter / backfire FiTech fuel injection (UPDATED) #2610160
01/21/19 11:29 PM
01/21/19 11:29 PM
BDW Online content OP
BDW  Online Content OP
70 Challenger / 340 / MP electronic ignition with Orange box (>20yr system), Fitech fuel injection.
Car has been running great since the Fitech install over a year ago. I mainly just cruise the car. It never really gets over 2500 RPM since I have 518 OD.
Other day I got on the gas and it sputtered and seemed to backfire. Did this several times each time I jumped on the pedal. Once I let up, it ran great as usual.
Any thoughts on where to look to figure this out?
Thx
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610225
01/22/19 01:12 AM
01/22/19 01:12 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Fuel pressure low or filter clogged,old fuel maybe. I'd check ignition timing and make sure your vacuum and mechanical advance are functioning properly.Is there any self diagnostic modes/codes that can be retrieved from the FItech unit,sensors and the like?
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610226
01/22/19 01:17 AM
01/22/19 01:17 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Backfiring is typically a timing issue.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610236
01/22/19 01:34 AM
01/22/19 01:34 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Don't rule out plugs or wires either,it could be that simple.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610432
01/22/19 02:48 PM
01/22/19 02:48 PM
K
Kiddart Offline
Kiddart  Offline
K
pending what Fitech he has some call out for dizzy to be locked out and the fitech takes care of the timing curve. look at that as well as all the fuel filters, and pressure etc..
Thank you
Kiddart
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610433
01/22/19 02:50 PM
01/22/19 02:50 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Check all the above and drive the snot out of it so the self learning algorithm can do its thing. Sounds like you baby it a bit and the computer doesn't get much of a chance to learn above 2500. Maybe shut the OD and converter lock (if so equipped) for a while if you're not into thrashing your baby.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610440
01/22/19 03:02 PM
01/22/19 03:02 PM
All good input,
I'll look over the plugs and wires
Look for vacuum leaks
Check the timing
I don't have FiTech controlling the timing.
I was wondering if it needed to learn the WOT.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610463
01/22/19 03:30 PM
01/22/19 03:30 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Yes the fitech needs to learn all variables and scenarios, you can go in and adjust some settings for those conditions as well.
Doing some data logging will help you correct some of the adjustments.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610499
01/22/19 04:21 PM
01/22/19 04:21 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Backfired out the exhaust or the intake? IAC reading on the handheld?
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610542
01/22/19 05:16 PM
01/22/19 05:16 PM
I'm pretty sure it backfired through the manifold.
I wasn't looking at the handheld
Is fhe IAC set up during install, like an idle adjustment.
I remember during the initial install the car wouldn't idle and ran like crap until I got a setting to 6-8. Seemed to recall that was the IAC?
Re: Sputter / backfire FiTech fuel injection [Re: John_Kunkel] #2610562
01/22/19 05:53 PM
01/22/19 05:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Be pretty hard to backfire out the exhaust, that would be a misfire.
Don't be the exception.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610587
01/22/19 06:47 PM
01/22/19 06:47 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
He’s likely asking about the IAC to see if it’s still working after the backfire. Though, it has nothing to do with a backfire.
I suppose if it’s lean enough you can get a backfire, I would log and see what’s happening. Most time people jam on the throttle and have an issue is because they need more accel or fast accel fueling.
2020 RAM 1500
Re: Sputter / backfire FiTech fuel injection [Re: Supercuda] #2610725
01/22/19 10:35 PM
01/22/19 10:35 PM
Rio Linda, CA
Rio Linda, CA
Oh? Excessive fuel in the exhaust system that ignites is a "backfire" where I come from.
Re: Sputter / backfire FiTech fuel injection [Re: John_Kunkel] #2610743
01/22/19 11:02 PM
01/22/19 11:02 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
How dare you question the Mighty Supercuda.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2610783
01/22/19 11:53 PM
01/22/19 11:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Get over your self.
A backfire fires backward, out the intake. A fart out the tailpipe is a misfire. two completely different problems.
Re: Sputter / backfire FiTech fuel injection [Re: Supercuda] #2610932
01/23/19 11:17 AM
01/23/19 11:17 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Get over your self.
Easy, killer.
Society has been referring backfires out the tailpipe since cars have been running. It is accepted terminology in the industry.
- Stu Harmon
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2611096
01/23/19 03:43 PM
01/23/19 03:43 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
As mentioned it could be a lot of issues, but the Fitech sets codes, look on your controller and see what if any codes have been set, if no codes are set, I would look at ignition system first. The other thing to check is that there is a filter screen on the pressure regulator valve if you take it out. I have had the one on mine get clogged and it caused it to run bad. The injector drivers in the computer will shut down if you have to much fuel pressure, it takes more amperage to lift the pintle off the seat of the injector.
Re: Sputter / backfire FiTech fuel injection [Re: Supercuda] #2611100
01/23/19 03:54 PM
01/23/19 03:54 PM
Rio Linda, CA
Rio Linda, CA
https://en.wikipedia.org/wiki/Back-fire
First sentence says it all.
Re: Sputter / backfire FiTech fuel injection [Re: John_Kunkel] #2611786
01/24/19 08:44 PM
01/24/19 08:44 PM
dogdays Offline
dogdays  Offline
Right On! Mighty backfires on a car of mine blew the muffler completely off. They were LOUD! I discovered it would happen after I hooked an AIR pump up on my Mercedes but did not use the Anti Backfire Valve. When I took foot off the gas, extra fuel got sucked out of the carb and when it came out the exhaust valve and ran into that nice stream of fresh air the explosion could be heard for quite a ways. I thought it was funny until the muffler got blown off. The outside of the muffler had flattened right out and the insides were bouncing on the pavement. Then I had to buy a new muffler and figure out how to avoid the backfires.
R.
Re: Sputter / backfire FiTech fuel injection [Re: BDW] #2612207
01/25/19 07:10 PM
01/25/19 07:10 PM
Update,
I checked the plug wires and noticed some cracks in the outer rubber.
I had another set, so I replaced them and took the car for a ride.
No backfire and ran great. Coincidence or could that have been it?
