Re: Can you make a Dominator carb streetable?
[Re: GY3]
#2610175
01/21/19 11:50 PM
01/21/19 11:50 PM
moparpollack
Lil Herman
Lil Herman
85086
Yes
[Re: GY3]
#2610192
01/22/19 12:14 AM
01/22/19 12:14 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I actually feel that they’re easier to dial in for street duty when the cam is on the big side(lower engine vacuum), since that’s what the low speed circuits are designed to be used with.
[Re: GY3]
#2610366
01/22/19 12:31 PM
01/22/19 12:31 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Yes. Pro Systems did a great job w/ mine.
[Re: GY3]
#2610368
01/22/19 12:46 PM
01/22/19 12:46 PM
Posts: 12,150 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have ran Dominators on my mostly street cars for over 15 years. No difference in driving quality vs a 4150 when set up right. And Thumper is the man to do that. If your combo needs/wants that much carb, there is no reason not to.
Master, again and still
[Re: AndyF]
#2610476
01/22/19 03:49 PM
01/22/19 03:49 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
I'd never recommend a 3 circuit for the street. You can kill an engine on a short freeway drive with a 3 circuit. Driving at part throttle with the manifold vacuum under the throttle blade sucking fuel right out of the intermediate dump tubes will wash the cylinders and stick the rings. I've seen customers over the years destroy expensive engines doing that. That is why I lean down the transition and idle circuits to prevent them being way to rich at light part throttle cruise on the street Dominic, Thumper Dart,760-900-3895, can fix them up for anyone wanting to drive a 3 circuit on the street
[Re: GY3]
#2610482
01/22/19 04:00 PM
01/22/19 04:00 PM
an8sec70cuda
FWIW...My Pro Systems 1200 cfm dominator is a 3 circuit carb. Granted it's obviously been modified, but the 3 circuit carbs can be made to work. As delivered from Holley, the 3 circuit carbs are pig fat and run like crap at part throttle.
[Re: GY3]
#2610485
01/22/19 04:07 PM
01/22/19 04:07 PM
fast68plymouth
So. Burlington, Vt.
As delivered from Holley, the 3 circuit carbs are pig fat and run like crap at part throttle. Frankly.......... the ootb 2 circuits aren’t much better. For truely street friendly manners, any of them are going to need some mods.
[Re: mopar dave]
#2610497
01/22/19 04:19 PM
01/22/19 04:19 PM
Posts: 391 kansas
farmboy
kansas
Absolutely! Call Dom at Thumpercarbs. Can find him on Facebook. He builds them weekly and is the best in the business in my opinion. I have one of his and it's the best carb I have ever owned. Ditto
[Re: Cab_Burge]
#2610603
01/22/19 07:14 PM
01/22/19 07:14 PM
BradH
I'd never recommend a 3 circuit for the street... ... Dominic, Thumper Dart,760-900-3895, can fix them up for anyone wanting to drive a 3 circuit on the street Yeah, but they're not 3-circuits any longer once he's gone through 'em. Anyone have experience w/ the HP-style 8082 1050? I'd heard that's more like the old-style 9375, in that it's a 2-circuit intended for a single 4-bbl application. It's not one of the fancy "new gen" billet series, though.
[Re: hemi-itis]
#2610630
01/22/19 08:17 PM
01/22/19 08:17 PM
Posts: 4,684 Wichita
GY3
Wichita
I'D bet he would get into the 10's with a thumperized tater! Been 10's already...
