57 Belvedere - a few fixes
#2609733
01/21/19 02:46 AM
01/21/19 02:46 AM
Posts: 152 Longview, TX
mopardwh
Longview, TX
Hey guys. I've got a really nice 4 door Belvedere, with 29K original miles. The only thing I'm aware of non-original, is a repaint in the 90's. I've been enjoying it for a little while, but I need to do few minor repairs.
1) The generator quit charging. Should I just convert to an alternator, or are there parts available?
2) The heater core started leaking in the floor board. Where can I get a replacement?
3) The horn button is really sloppy and will contact when turning. Haven't taken it apart yet, any easy fixes there?
Thanks!
Doug
Re: 57 Belvedere - a few fixes
[Re: mopardwh]
#2609769
01/21/19 09:38 AM
01/21/19 09:38 AM
Posts: 1,511 AZ
Mike P
AZ
Charging problem is likely either generator or regulator. Both are still available thru different sources. With the number of hot rod 57/58 Plymouth and dodges being built on this site you might even be able to find good used units laying around someones garage. An alternative to replacement is also rebuilding the generator (not a hard job with a service manual handy) and cleaning and gaping the points on the regulator. An alternator is also an easy upgrade......if you go that route, I'd recommend using an alternator with an internal regulator or a 1 wire unit.
Because of the design of the heater plenum on the outside of the fire wall and the drain holes located below the core a leaking heater core generally does not leak inside the car. The most likely source of the leak inside the car is the heater control valve (where the heater hoses connect on the lower right hand side of the heater box on the firewall. Rebuild kits for the valve used to be available from NAPA but don't know if they still are. A universal heater valve can be used in place of the original (spliced into the heater hose) but will likely require changing the control cable on the lever.
Check to make sure both screws that hold the horn ring are there and tight. The correct screws will bottom out at the correct depth to allow the horn to be pressed but not make contact until the horn is pressed. Also make sure the spring is in pl,ace under the center of the horn ring.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: mopardwh]
#2609796
01/21/19 11:38 AM
01/21/19 11:38 AM
mopardwh
Longview, TX
Great info! Thank you so much. I've owned dozens of Mopars mid-60's and up, but this is my 1st one thats older. Sounds like the control valve is still about the same though. Easy fix. I really appreciate that.
Doug
