3000hp KABOOM #2609536
01/20/19 09:13 PM
01/20/19 09:13 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
Re: 3000hp KABOOM [Re: GomangoCuda] #2609540
01/20/19 09:33 PM
01/20/19 09:33 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I've been at some cheesy dyno rooms where the the walls are drywall. Never again!
Re: 3000hp KABOOM [Re: GomangoCuda] #2609631
01/20/19 11:17 PM
01/20/19 11:17 PM
That must have been one of the 2000, 2001 blocks that Cummins had casting problems with shruggy
A friend of mine bought a 2001 345 HP H.O. that develop a crack on the bottom of the block on the drivers side that started leaking coolant right before it had 1000,000 puke
It had been hopped up by Dave Smith Dodge from day one and he had them do upgrades to it about every year when he would drive it from SO CA to eastern Montana to visit several of his children that lived up there.
He had the extended 10 year, 100,000 warrenty on it, Dave Smith had done another upgrade to the motor at 99,850 miles just before it starting stinking like antifreeze. Dodge ended up replacing the short block for no charge boogie
He let a diesel hop up company in Las Vegas ,NV sell him a camshaft that I had warned him about not buying and he learned the hard way the stock stuff works pretty well when all the mods done to most of those trucks are based on stock cams and so on, it lost a bunch of torque on the chassis dyno with the new short block and camshaft whiney work
The local Dodge dealer did the short block replacement along with installing the new cam work shruggy I'm sure none of those guys knew anything about degreeing a camshaft work shruggy
Re: 3000hp KABOOM [Re: GomangoCuda] #2609632
01/20/19 11:19 PM
01/20/19 11:19 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Somewhere I saw one blow up like that in a truck at the dragstrip. Shop truck for one of the diesel shops.
Re: 3000hp KABOOM [Re: CMcAllister] #2609640
01/20/19 11:36 PM
01/20/19 11:36 PM
Can you imagine that thing blowing the front off your racer near the finish line? Wonder how bad it tore up the dyno.
Re: 3000hp KABOOM [Re: GomangoCuda] #2609673
01/21/19 12:33 AM
01/21/19 12:33 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It seems once they get the head gasket locked down the block splits between the mains and the deck, i have seen that on several big I6 diesels in tractor pull videos also.
68 Barracuda Formula S 340
Re: 3000hp KABOOM [Re: GomangoCuda] #2609718
01/21/19 02:28 AM
01/21/19 02:28 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Saw a few on TV watching tractor pulling.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 3000hp KABOOM [Re: CMcAllister] #2609726
01/21/19 02:36 AM
01/21/19 02:36 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The electronic fuel shut off failed and it was running away, the driver either put in in neutral or down shifted and let it blow. I forget how many pounds of boost the data logger showed before it blew but it was a bunch.
Re: 3000hp KABOOM [Re: justinp61] #2609784
01/21/19 11:09 AM
01/21/19 11:09 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
shock
Saw a diesel run away with a tech once. He had replaced the short block and came back in the shop with it screaming. Several of us ran over and stuffed a work jacket into the air intake and choked it down. Scary couple of minutes.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
