69 Charger lower ball joint...replacement didn't fit! #2607893
01/17/19 02:02 AM
01/17/19 02:02 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Just attempted to replace the lower drivers side ball joint. Got a replacement online, part number was K783, which is what Classic Industries and the auto parts store say is correct. After breaking the old one free...no fun job..I put the new one in, but the arm that connects to the tie rod end does not have the correct curvature to clear the brake drum. Looking at the original ball joint, its stamped with 22-4002. I could not find this casting/part number anywhere! Any ideas? Do I have a different control arm/ball joint from a different model? Car was supposed to go to a car show on Saturday...now its sitting on jack stands.... Any assistance would be appreciated. Thanks!
Dave in Colorado
Re: 69 Charger lower ball joint...replacement didn't fit! [Re: dssaa] #2607900
01/17/19 02:10 AM
01/17/19 02:10 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
pictures would help
Re: 69 Charger lower ball joint...replacement didn't fit! [Re: dssaa] #2607912
01/17/19 02:38 AM
01/17/19 02:38 AM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I think I was just sent the wrong part. I compared it to my SuperBee, and its definitely not correct. I am swinging by the auto parts store tomorrow and matching up the correct one...which I should have done in the first place.
Re: 69 Charger lower ball joint...replacement didn't fit! [Re: dssaa] #2608340
01/17/19 11:58 PM
01/17/19 11:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
It sounds to me like someone put the wrong part in a box, and you were the lucky recipient.
I got a fuel regulator once, the box had the correct number on it, the part even had the correct number on it, but it was the wrong part! I had to send pictures of the part, they did send me the correct part, but it did cost me about a week worth of messing around. That part was boxed wrong at the factory.
Stuff happens. Gene
Re: 69 Charger lower ball joint...replacement didn't fit! [Re: poorboy] #2608387
01/18/19 01:38 AM
01/18/19 01:38 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I sold auto parts for years. You would not believe the crap that gets mislabeled or put in the wrong box. Probably boxed on a Friday or a Monday! People either not paying attention or hung over.
Re: 69 Charger lower ball joint...replacement didn't fit! [Re: elmor353] #2608474
01/18/19 09:34 AM
01/18/19 09:34 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Saw a set of 8 .030 pistons once, all stamped .030 on top of piston. THREE were STANDARD SIZE!!! Machine shop that sold them and bored the engine missed them. "Experienced" mechanic that assembled the engine missed them. (machine shop took the hit and made it right) jess
Yeah, it's hopped up to over 160...
Re: 69 Charger lower ball joint...replacement didn't fit! [Re: jt4406] #2609049
01/19/19 05:19 PM
01/19/19 05:19 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
How does a machine shop& a mechanic both miss a std compared to 0.030 over piston,nobody know how to use mics?
Re: 69 Charger lower ball joint...replacement didn't fit! [Re: GarageDodge] #2609082
01/19/19 06:36 PM
01/19/19 06:36 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Agreed. Those three standard pistons would've rattled around in the bores like a baseball bat in a garbage can.
