Headers 4 a 75 Cordoba 360
#2608335
01/17/19 11:53 PM
01/17/19 11:53 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I have this Doba I would like to use for a daily driver this comming summer. Looking at Accurate exhaust advertising here. They have a complete system for duals at over $800oo. They also say they are in limited supply. I was wondering if there might be a header for this thing. I can get the rest done at the local shop. Don't wanna throw a grand at this thing for exhaust. Thanx in advance folks.
I have mechanical Aptitude. I can screw up anything.
Re: Headers 4 a 75 Cordoba 360
[Re: elmor353]
#2608365
01/18/19 12:45 AM
01/18/19 12:45 AM
bboogieart
Lost and Spaced
Thanks for the response.
That is a little spendy for this toy.
[Re: scratchnfotraction]
#2608697
01/18/19 06:22 PM
01/18/19 06:22 PM
bboogieart
Lost and Spaced
looked at JEGS, could find no such header. Might you have a link? Same at Summit.
Yes, a b-body, but unlike the older ones, due to front sub frame I would guess.
I was thinking of exiting in front of rear wheels. Not looking to kill any kritters, but I appreciate the responses and the short story. I will have the pipes come out under the rear bumper.
Guess I'll see what Fran wants in town. thing is I wasn't really looking for headers. Couldn't find the head pipes anywhere.
Thanx guys.
[Re: bboogieart]
#2608791
01/18/19 10:36 PM
01/18/19 10:36 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
Install a pair of exhaust manifolds from a mid-90's Ram or Dakota with a 318 or 360. They are a great design & should fit. I installed a pair of these on my 73 Charger 340 when I had it & they fit better than the original manifolds! Only thing I had to do was have a new trans dipstick assembly made as the RH side manifold interfered with the OE dipstick.
[Re: elmor353]
#2608916
01/19/19 10:51 AM
01/19/19 10:51 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I just went to Jeg's website and had better luck. Looks like they have headers to fit your Cordoba starting at $250. In my way of thinking that's more like it. $250 for a set of uncoated headers, that will be rusty in less than a year, doesn’t sound so good to me, especially if it’s a daily driver.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: bboogieart]
#2608932
01/19/19 11:57 AM
01/19/19 11:57 AM
RWG75
RWG75
Yes, a b-body, but unlike the older ones, due to front sub frame I would guess. .... thing is I wasn't really looking for headers. Couldn't find the head pipes anywhere.
The front sub frame change was 73. Most header application pages wont include 75/up because of emissions and generally omit Dobas because not considered a performance vehicle. Just about anything spec'd for small block B-body will fit. A couple tubes on drivers side go under the tie rod, passenger side is a bit snug, some install instructions say floor shift only but there's usually room to get around column shift. If you're going headers only because you can't find an off the shelf head pipe, find a exhaust shop with skill. Custom bent duals from manifolds to bumper can be had for $500ish plus mufflers. Been a few years since I had any bent, your prices may be subject to inflation. I always supply my own mufflers to get what I want and skip the shop mark up. Getting past the gas tank on the drivers side is tight, but again an exhaust shop with skill can do it. FWIW: best money to spend on waking up this pile of steel is swapping the rear gear. Probably 90% of them shipped with a 2.45 that will give long legs and decent mpg on the highway but won't get out of it's own way. Ya won't need more than a 3.21 to have a completely new car. Add a swap meet cast iron 340 intake, a TQ and maybe a purple shaft (if they still make them) and it's bucks down, fun up.
[Re: elmor353]
#2610623
01/22/19 08:00 PM
01/22/19 08:00 PM
bboogieart
Lost and Spaced
He asked about headers that fit. He didn't specify painted or coated. I don't see where you did any research to try and help the OP, just snide and negative remarks. Thanx elmor353 I also mentioned the local shop would be my next best option. The car does Ok for get up and go, considering it's weight. I have a 4 bbl and plan on an RV cam for some grunt.
[Re: Spaceman Spiff]
#2611120
01/23/19 04:22 PM
01/23/19 04:22 PM
Posts: 15,902 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just went to Jeg's website and had better luck. Looks like they have headers to fit your Cordoba starting at $250. In my way of thinking that's more like it. $250 for a set of uncoated headers, that will be rusty in less than a year, doesn’t sound so good to me, especially if it’s a daily driver. I agree. Also, headers are one of those things that you get what you pay for. I'd spend more now and avoid the headaches later. I get not wanting to dump a bunch of money into this car, but I LOVE YOUR DOBA! I think you should call TTI and see if they have something. I bet they do, and they'll seal up so nicely, and be trouble free for years and fit very well.
Facts are stubborn things.
[Re: bboogieart]
#2611180
01/23/19 07:18 PM
01/23/19 07:18 PM
Porter67
$175 shipped Ive bought a couple sets of these for beaters and they are actually nice for the cost. China stainless. Headman knockoff This part is compatible with 1 vehicle(s) matching 1975 Chrysler Cordoba Base Hardtop 2-Door 5.9L 360Cu. In. V8 GAS OHV Naturally Aspirated. https://www.ebay.com/itm/Long-Tube-Exhau...0/333018998049?
[Re: Jerry]
#2611272
01/23/19 10:26 PM
01/23/19 10:26 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
just found a summit brand that may go over the steering linkage, for $152 Could you share who makes them and a part number? I am interested in checking them out.
