Re: Correct front wheel cylinders for 10" drum brake A-Body?
[Re: vinnyd76]
#2607617
01/16/19 05:08 PM
01/16/19 05:08 PM
RapidRobert
^^^ first sentence is correct. not sure if the other is or is not. EDIT looking at the bottom one closer it appears to the same double flare but there is the smooth extension of the male fitting. I would see what the inside threaded area on the old wheel cyls looks like.
[Re: vinnyd76]
#2607825
01/16/19 11:36 PM
01/16/19 11:36 PM
Posts: 601 Mass
charge70
Mass
All 10" A-body flex hoses screw directly into the wheel cylinder.Only 9" A-body brakes use that small steel line between the hose and the cylinder.Also the pic of the wheel cylinders you posted shows the bleeder straight out,all 10" brakes I've seen have the bleeder coming out at an angle to clear the spindle.Something not right here
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: vinnyd76]
#2607838
01/16/19 11:58 PM
01/16/19 11:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Those are not 10" drum wheel cylinders. Get a copy of the FSM, in the brake section it is clearly shown. http://www.mymopar.com/index.php?pid=109The Raybestos ones match the FSM. You either do not have 10" front drums or someone put wheel cylinders out of a 9" drum in there.
[Re: Supercuda]
#2607865
01/17/19 01:10 AM
01/17/19 01:10 AM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
Those are not 10" drum wheel cylinders. Get a copy of the FSM, in the brake section it is clearly shown. http://www.mymopar.com/index.php?pid=109The Raybestos ones match the FSM. You either do not have 10" front drums or someone put wheel cylinders out of a 9" drum in there. Thank you very much for the service manual link! One key point that I read in both the Dart and Duster manuals is the following snip. Does that not reference this small jumper line?
[Re: vinnyd76]
#2607997
01/17/19 12:01 PM
01/17/19 12:01 PM
Supercuda
About to go away
About to go away
up yours
9" drum ONLY
If you have that you have 9" drum parts
[Re: Supercuda]
#2608016
01/17/19 12:35 PM
01/17/19 12:35 PM
vinnyd76
Macomb, MI
9" drum ONLY
If you have that you have 9" drum parts Take a look at this file that I received this morning. It appears all these new wheel cylinders today require a bubble flare and double flare for the steel line to attach to the wheel cylinder and the rubber brake hose (reference above).
