Re: Is there a fix for wheel wobble on stock suspension?
[Re: Bad340fish]
#2607446
01/16/19 01:25 PM
01/16/19 01:25 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Thanks everyone for your feedback!
Bad340fish, yep, I already spoke to Jim this morning and taking it to him as soon as I get the motor back in. He said he may put a B-body tie rods on it as well as checking out all the other components.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#2607480
01/16/19 02:12 PM
01/16/19 02:12 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Yes good parts are a must. But it is not just the contributing factor. when coming down it is going threw a caster change and a toe change. the thing is to minimize toe change (bump steer).info in mopar chassis book. dougs car has very little bump steer. oops saw someone beat me to that.
JAKES AUTOMOTIVE
[Re: ss/la]
#2607528
01/16/19 03:22 PM
01/16/19 03:22 PM
Posts: 391 kansas
farmboy
kansas
wade get a copy of the old direct connection race manuals. this is called bump steer and it does cost et not much but some. the race manual show you how to map your front end out from all the way up to all the way down. you have to raise or lower the point of contact from the outer tire rod to the spindle. there are people that sell bump steer kits they work too. google bump steer I have used the manual on many cars, PIA to do, but it does help. Best fix is rack and pinion, but lots of geometry issues with that too.
[Re: WadeMetzinger]
#2607591
01/16/19 04:27 PM
01/16/19 04:27 PM
Posts: 2,926 A shed in England
Tig
A shed in England
The video of the challenger is from 2010 and I've done some work on it since then. Replacing all the bushes including the idler arm helped but didn't eliminate it. Limiting travel helps but may cause traction issues, especially with Caltracs.I also found out that E bodys use 2 different Pitman arms on manual steering boxes and they have to match the idler arm or the heights are different, this will mess up the bumpsteer as each side will then do it's own thing. At the same time, I flipped the tie rod ball joint/steering link bar to help with toe out on extension, but it still does it, though to a much lesser degree. I'm replacing the stock K member with a QA1 tubular after a big wheelie elongated cracked the LCA/torsion bar pivot mount, maybe this will help. IMHO, the only way to eliminate it entirely is going to a strut type front. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: AndyF]
#2607719
01/16/19 08:51 PM
01/16/19 08:51 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I have these on my car and it still does it. I think it happens when there is very little weight on the front tires. If you will go back and look at old Hemi Challenge races, before they tied them down so much, almost all of the SS/AH cars did it at the time. Here is a slow motion leave for my car and you can see them wobble. This is probably aggravated by the fact the most of us run so little toe in. My car has had the bump steer corrected. https://www.youtube.com/watch?v=TB47w1GF6TY&feature=youtu.be
[Re: 340Cuda]
#2607798
01/16/19 11:02 PM
01/16/19 11:02 PM
Posts: 1,841 South Bend
John Brown
South Bend
A steering damper, like is used on VW's and Monte Carlo's. Used to see that problem a lot on old straight axle drag cars. Basically it's a sideways shock absorber.
[Re: John Brown]
#2607853
01/17/19 12:41 AM
01/17/19 12:41 AM
Posts: 4,692 Wichita
GY3
Wichita
A steering damper, like is used on VW's and Monte Carlo's. Used to see that problem a lot on old straight axle drag cars. Basically it's a sideways shock absorber. My truck started doing the death wobble thing. Put a new steering damper on it and it was cured. Very simple setup.
[Re: WadeMetzinger]
#2607965
01/17/19 09:55 AM
01/17/19 09:55 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
When my Valiant was doing this I tightened the top control arm bolts super tight and it cured it.
[Re: WadeMetzinger]
#2608062
01/17/19 02:21 PM
01/17/19 02:21 PM
Posts: 2,663 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
My buddy's 68 Barracuda did the same exact thing. It would eventually loosen the bolts holding on the steering box. The fix is simple but sadly it's been a few years and I can't remember it all. Maybe it's bump steer? Maybe the fix was rod ends for the outer ball joints. Sorry I can't remember the exact process.
2011 Drag Pak Challenger
[Re: WadeMetzinger]
#2608372
01/18/19 01:04 AM
01/18/19 01:04 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
wade i have noticed that your front tires lean in more than mine do. Although they both seem to look fine when parked. That might be a function of different brand of front end parts?
Wade's photo is from Mary Robinson(I had to crop it out to make it fit)
68 Barracuda Formula S 340
[Re: WadeMetzinger]
#2608385
01/18/19 01:35 AM
01/18/19 01:35 AM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
looks like the upper bump stops are gone, or have been cut down
[Re: CSK]
#2608539
01/18/19 12:52 PM
01/18/19 12:52 PM
WadeMetzinger
Tulsa, Ok
My upper bump stops are cut down to almost down to the numb for more travel.
[Re: WadeMetzinger]
#2608568
01/18/19 02:02 PM
01/18/19 02:02 PM
CSK
Pattison Texas
My upper bump stops are cut down to almost down to the numb for more travel. In my opinion that is A LOT of the problem, that car hooks good, replace the bump stops & play with the rebound on front shocks.good double adj shocks would be the best, bet the car would et better
