Re: best way to increase hp in my 318?
[Re: Moparmad]
#2607846
01/17/19 12:21 AM
01/17/19 12:21 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
This was the California emission variety. I did install 4 barrel aluminum intake with fitech fuel injection. I will look on the block and get the date I think it is a mid 80’s though Block is less important. Head casting numbers, which are under the valve covers, are more important. It was in the mid 80s when high swirl heads were being released, but they still had open chambers (less than ideal squish and compression). It wasn't until the 90s that the small chamber, high swirl and tumble Magnum heads came out. Hopefully ATK can give you the scoop on heads and cam. This would be link number 4 to this article that was first posted in reply #3.
[Re: Moparmad]
#2607999
01/17/19 12:05 PM
01/17/19 12:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
302 heads, mid 85 release, where small chamber, high swirl and tumble LA heads
[Re: Moparmad]
#2608027
01/17/19 12:54 PM
01/17/19 12:54 PM
Posts: 44 Texas
Moparmad
Texas
I confirmed it is 302 heads and they shoot for 9:1 CR. But they allow 3/10ths either way. Could be from 8.7:1 all the way to 9.3:1.
Casting date on block is 11/24/84
[Re: Moparmad]
#2608042
01/17/19 01:28 PM
01/17/19 01:28 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
302 heads, without some “work” done to them aren’t an easy path to 300hp+.
Even with some cost effective work(subjectively speaking), they’re not great.
IMO, better off selling them to someone who really wants a set and replacing them with something more hp friendly.
Alternatively, you throw some parts at it...... it makes what it makes, and you live with it and you start saving for that 360.
[Re: Moparmad]
#2608047
01/17/19 01:37 PM
01/17/19 01:37 PM
Supercuda
About to go away
About to go away
up yours
302 heads are fine for a mild build. Put a 340 cam in it, a 4bbl intake on it and a 318 with 302 heads can run nice. Is it even close to 300hp? Probably not, it is worth spending any more money than free on 302 heads for HP builds? Nope.
Now if they had made 308 heads with a closed chamber then we'd be talking.
Use magnum, heads if you are going with a stock type casting for a HP build.
[Re: Moparmad]
#2608121
01/17/19 03:45 PM
01/17/19 03:45 PM
Posts: 735 Pa. U.S.A.
moparborn
Pa. U.S.A.
if you up the valves on those heads to 1.88 and 1.60 and do some port work ,they will make over 300 horses ,and more with assistance(turbo,supercharger).
[Re: roadrunninMark]
#2608662
01/18/19 04:53 PM
01/18/19 04:53 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
and this is without get new pistons closer to deck... and composite headgaskets ?
[Re: Moparmad]
#2608745
01/18/19 08:21 PM
01/18/19 08:21 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I’m surprised nobody asked what read gears you are running. I know that wasn’t in your question but it has everything to do with the answer. Start with 3.23SG bare minimum. Doesn’t matter go much HP you make if you don’t have the gears.
I’m listening.
#2608768
01/18/19 09:32 PM
01/18/19 09:32 PM
TC@HP2
Pikes Peak Country
TC...actually my link is a different article than posted in reply #3. Completely different test with additional information. So it is. My bad.
